Author Topic: Monitor is getting slow to turn on?  (Read 4471 times)
Bill_S
  • Last login:June 22, 2018, 08:23:57 am
  • aka buzzdalf
« on: June 11, 2003, 12:18:10 pm »
I've got a 20" PC monitor that is taking a long time to turn on.  You plug it in and power it up, then wait about 5 minutes to get a picture.
If I turn it off, and then right back on, it seems to power up normally.
Also, after it's been on a long time, the picture slowly fades back off.
Any ideas on what causes this?
Is the tube going bad??
spectre
  • -- banned --
  • Last login:April 07, 2004, 08:45:11 am
  • -- banned --
Re:Monitor is getting slow to turn on?
« Reply #1 on: June 11, 2003, 07:20:35 pm »
I would assume that it means it's broke, and since the tube displays the picture, it's probably the tube, but i dunno anything, just my assumption
-- banned --
StephenH
« Reply #2 on: June 15, 2003, 03:11:25 pm »
I would assume it is either the tube or something in the power supply.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: June 18, 2003, 01:32:09 am »
I had a monitor behave exactly like that at work.  They took it into the shop, and it came back fixed for ~$100 IIRC.  (not out of my pocket, so I didn't really note the amount at the time).  IIRC, it was a cap problem, but again, it was not my personal monitor, so I didn't bring it in nor did I ask much about it.
Not much info, sorry.
Robin
Knowledge is Power
Bill_S
  • aka buzzdalf
« Reply #4 on: June 19, 2003, 12:18:47 pm »
That helps actually.  This is a monitor at work they are getting ready to throw away.   They just replaced it because of the mentioned behavior.
I've got a gate pass to take it home, but didn't know if it was worth my hassle.
Maybe it is...
