Author Topic: MAME .70 Released (n/t)  (Read 4102 times)
SirPeale
  • Green Mountain Man
« on: June 11, 2003, 07:49:33 am »
Okay, some text, as it was required...
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
Re:MAME .70 Released (n/t)
« Reply #1 on: June 11, 2003, 08:27:49 am »
so what's new with it?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: June 11, 2003, 09:36:18 am »
0.70
This contains all the updates listed which were part of the source only diffs listed below
(0.69a, 0.69b, 0.69u3) plus a few extra bits and pieces.  A couple of drivers still appear to
be broken with the new timer system (deadang, artmagic for example) but hopefully most of the
problems were ironed out.
General Source Changes
Konami GX Sound Improvements [R.Belmont]
General Konami Updates [Acho A. Tang, R. Belmont]
Various Dipswitch fixes / conversion of drivers to tilemaps [Curt Coder]
Removed hacks from Oriental Legend [Olivier Galibert]
   src\drivers\pgm.c
Some D3D updates / fixes [Leon van Rooij]
Sanity checks for Ports [Pierpaolo Prazzoli]
   src\mame.c
Documentation updates [Santeri Saarimaa, Randolph, Leon van Rooij]
Improved bios selection code, now -bios japan can be used with the NeoGeo driver for
example [Paul Priest]
New clones supported
Korosuke Roller (clone of Crush Roller) [BUT, nono]
   src\drivers\pacman.c
New TESTDRIVERS in source
DJ Boy [Phil Stroffolino]
   not working due to protection
   src\drivers\djboy.c
   src\vidhrdw\djboy.c
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #3 on: June 11, 2003, 10:01:20 am »
hey that's my line....
HeadRusch
  • Last login:September 02, 2006, 04:13:30 pm
  • ....Here you are all EQUALLY WORTHLESS...
« Reply #4 on: June 11, 2003, 11:49:18 am »
Just saw a round of 3D games go through USENET.....games like Virtua Fighter......Rival Schools...etc.....are these games to be emulated in a soon to be release, or is this just the standard release pattern for roms to "hold onto cuz someday you might need em" kinda thing....
".....its like a Koala crapped a rainbow in my brain!"
rampy
  • *shrug*
« Reply #5 on: June 11, 2003, 11:54:46 am »
Zinc was updated yesterday.. coincidence? I think not =P
Rampy
Mike
  • Last login:September 22, 2005, 01:22:14 pm
  • Umm, yea about the TPS report
« Reply #6 on: June 11, 2003, 11:56:55 am »
Some of them are already emulated in Modeler and some other emus.
Frostillicus
  • Arcade Artist
« Reply #7 on: June 11, 2003, 01:07:09 pm »
*checks BYOAC script, Scene I -
The latest version of Mame has just been released, and is, of course, announced again without an accompanying 'what's new' bit.
Rampy: so what's new with it?*
Ah, my bad.   ;D
HeadRusch
« Reply #8 on: June 11, 2003, 01:29:54 pm »
*cough*Cough*..... ;)
zinc...riiight... ;)
rampy
  • *shrug*
« Reply #9 on: June 11, 2003, 02:19:15 pm »
From http://unemulated.emuunlim.com/
"8th June, 2003
More Zinc WIP.....
Sadly, Soul Calibur can't be fully emulated until the dump is complete. It's emulated and runs but all graphics are bad (showing only garbage and colored pixels) because 2 ROMs are not dumped yet. If you want to help out, see MAMEWorld for more info :)"
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
« Reply #10 on: June 11, 2003, 02:20:18 pm »
Good news! ;D
Now with cup beer holders!
SirPoonga
  • Puck'em Up
« Reply #11 on: June 11, 2003, 03:19:28 pm »
0.69u3 (0.69 Update 3)
source diff, changed numbering system to ux instead of a,b,c because people were getting
confused and thinking mame069b.zip (mame 0.69 _b_inary) was the updated version when it
wasn't.
misc fixes and improvements this time, no changes related to the timer system so as far
as testing that goes this isn't an essential upgrade.
if you use this code in your own build of Mame please make sure you use the correct
version number to reflect the inclusion of this updated code.
Direct 3D update to change the way cleanstretch is handled [Leon van Rooij]
   -cleanstretch works like this:
   -cleanstretch auto: let blitter decide, the same as -nocs in 0.69 (default).
   -cleanstretch full: same as -cs in 0.69
   -cleanstretch none: disable (won't look good with scanlines)
   -cleanstretch horizontal: horz only
   -cleanstretch vertical: vert only
Added Ozon 1 Prom [Pierpaolo Prazzoli]
   src\drivers\galaxian.c
Added correct roms to Mighty Monkey (bootleg on Super Cobra Hardware) [Pierpaolo Prazzoli]
   src\drivers\scobra.c
Fixed some problems in the makefile for the xml2info program [Andrea Mazzoleni]
   makefile
   src\core.mak
Fixed crash in usclssic []
   src\drivers\seta.c
Fixed problem where controls stopped working after the first level in Tugboat [Tomasz Slanina]
   src\drivers\tugboat.c
Changed MULU timing in asm 68k core so that it matches the C ones [Razoola]
   src\cpu\m68000\make68k.c
Bug fix to loop addressing on YMF278B which helps stablise the tuning on looped samples
(noticable in parts of s1945 at least). [OpenMSX]
   src\sound\ymf278b.c
Fixed hedpanic sound banking []
   src\drivers\esd16.c
Corrected various clocks in the vball driver [TheGuru]
   src\drivers\vball.c
Field Day (now the parent of The Undoukai) [Tomasz Slanina]
   src\drivers\40love.c
King of Fighters '98 (alt M1) [Razoola]
King of the Monsters (set 2) [Razoola]
   src\drivers\neogeo.c
Various CPS2 clones [Razoola]
   src\drivers\cps2.c
Sparkman [Luca Elia]
   not working, protection
   src\drivers\suna8.c
0.69b (0.69 Update 2)
Another source diff update, this fixes some of the problems Mametesters discovered
with the new timer code, please test this well too, if anything else is broken which
worked in .69 let us know, it could be important.
Fixed Dipswitches and Inputs in Atlantic City Action / Broadwalk Casion [Peter Storey]
Fixed a few Misc Typos [Santeri Saarimaa]
   src\drivers\metro.c
   src\drivers\oneshot.c
   src\drivers\lethalj.c
Added 'Right' in Moon Shuttle [David Haywood]
Various fixes to the PIC16C5x core. [Quench]
   src\cpu\pic16c5x\pic16c5x.c
   src\cpu\pic16c5x\pic16c5x.h
   src\cpuintrf.c
Sound working in BIGTWIN [Quench]
   src\drivers\playmark.c
The use of the PIC HEX dumps for DRGNMST and BIGTWIN [Quench]
   src\drivers\drgnmst.c
Fixed a bug in the V60 CPU core causing it to break with the new timer system [Aaron Giles]
   src\cpu\v60\v60.c
Fixed a problem in snprintf.c printing out floats with fractional partswith leading
zeroes [Chris Kirmse]
   src\windows\snprintf.c
Fixed bug in K054539 causing bad vocals in Dadandarn [R.Belmont]
   src\sound\k054539.c
Added PGM Calender [Pierpaolo Prazzoli]
   src\drivers\pgm.c
Fixed a problem which caused sound to break in games using a YM2610 using the new timer
   src\cpuint.c
Changed NeoGeo to use boost_interleave for tight CPU communications instead of throwing
cyces away [Aaron Giles]
New games supported:
Space Cruiser [Tomasz Slanina]
   src\drivers\taitosj.c
Mustache Boy [Tomasz Slanina, Nicola Salmoria]
   previously a TESTDRIVER, decryption completed by Nicola
   still bad colours and no sound due to missing roms / mcu?
   src\drivers\mustache.c
   src\vidhrdw\mustache.c
Evil Stone [Tomasz Slanina]
   src\drivers\taito_l.c
Glass [Manuel Abadia]
   this isn't playable due to protection but I've enabled it anyway
   src\drivers\glass.c
   src\vidhrdw\glass.c
Tri-Pool [David Haywood]
   src\drivers\jack.c
Final Fight (Japan Set 2) [Razoola]
   src\drivers\cps1.c
   src\vidhrdw\cps1.c
SirPoonga
  • Puck'em Up
« Reply #12 on: June 11, 2003, 03:19:55 pm »
0.69a (0.69 Update 1)
This version is provided as a source diff only, more releases like this may follow
depending on how this one goes down, the intention is to allow people to have the
latest code without the hassle and bandwidth requirements of a new binary.
If you can't compile this then don't worry, normal releases will still happen, this
doesn't change anything as normal release plans are concerned, please don't hassle
whoever maintains your favourite port of Mame to add the updates here, not everybody
is going to have time to make new binaries on a regular basis.
Fixed eeprom in Head Panic [Paul Priest]
   src\drivers\esd16.c
Few tweaks/minor optimizations to MIPS3 Dynacrec [Aaron Giles]
   src\x86drc.c
   src\x86drc.h
   src\cpu\mips\mips3drc.c
Improved Save-State support for NeoGeo games [Mame32Plus]
Changed NeoGeo Resolution to be 320 wide, this is correct, the glitches it causes
are verified against a real MVS [David Haywood]
Verified and corrected clock speeds etc. for NeoGeo [TheGuru]
   src\machine\neogeo.c
   src\vidhrdw\neogeo.c
   src\includes\neogeo.h
Removed analog input definition and encoded it directly from
Joystick input in Metal Soldier Isaac II [Jarek Burczynski]
   src\drivers\msisaac.c
IDE Update adding support for a few things needed in the future [Aaron Giles]
   src\machine\idectrl.c
   src\machine\idectrl.h
TMS32010 BIO fix [Aaron Giles]
   src\cpu\tms32010\tms32010.h
C 68k core is now default, this fixes collisions in Assault []
Fixed bug causing Timings to be broken when using D3D [Leon van Rooij]
   src\windows\wind3d.c
Optional XML output and xml to info converter (see xmlinfo.txt) [Andrea Mazzoleni]
   use -listxml, converter isn't fully set up yet.
   src\info.c
   src\info.h
   src\windows\fronthlp.c
   src\xml2info\*
A number of Changes to the Timer System [Aaron Giles]
   All the CPU scheduling has moved into cpuexec.c and been taken out of
   timer.c. A number of bugs relating to time tracking for suspended CPUs have
   been fixed.
   A side effect of all this is a change in the behavior of the CPU scheduling.
   For the most part, games are fine with this. However, there were a few
   exceptions:
   * taitosj.c: timing of the MCU communication broke
   * arkanoid.c: timing of the MCU communication broke
   * harddriv.c: stunrun timing glitches, racedriv/steeltal/hdrivair broken
   (There may be more, but I haven't found them yet.)
   The first two problems have been fixed, as has racedriv, but steeltal,
   hdrivair, and stunrun still have issues.
   Oh, one other useful function I added is this:
      cpu_boost_interleave(double timeslice_duration, double boost_duration);
   You call this if you need to temporarily crank up the interleave for a short
   period of time in order to get CPU synchronization working. I used this in
   arkanoid and taitosj to get the MCU communications working. For example, you
   could say:
      cpu_boost_interleave(TIME_IN_USEC(1), TIME_IN_USEC(100));
   which would interleave the CPUs on 1 usec boundaries for the next 100 usecs.
   Even more useful is this:
      cpu_boost_interleave(0, TIME_IN_USEC(10));
   A very small value (0) for the first parameter means "use perfect
   synchronization", which should guarantee cycle-accurate synchronization for
   the specified duration. Note that this is *really* slow, so you don't want
   to be doing it too much!
   Let us know ASAP if anything else is broken as a result of this update
   src\cpuintrf.c
   src\cpuintrf.h
   src\cpuexec.c
   src\cpuexec.h
   src\timer.c
   src\timer.h
   src\machine\taitosj.c
   src\machine\arkanoid.c
   src\drivers\harddriv.c
   src\machine\harddriv.c
   src\sndhrdw\harddriv.c
Guts'n [Paul Priest]
   src\drivers\suprnova.c
   src\vidhrdw\suprnova.c
Dragonball Z [R.Belmont]
   src\drivers\dbz.c
   src\vidhrdw\dbz.c
   src\vidhrdw\konamiic.c
   src\vidhrdw\konamiic.h
Ozon I [Pierpaolo Prazzoli]
   bad colours due to missing prom
King of Fighters '95 (set 2) [Jarek Burczynski]
   note, we use the new v1,c1,c2,c3,c4 from this set in the parent too
Kyros No Yakata (Japan) [David Haywood]
   src\drivers\alpha68k.c
Ambush (Tecfri) [David Haywood]
   src\drivers\ambush.c
Frisky Tom (set 2) [David Haywood]
   src\drivers\seicross.c
Photo Y2K [ElSemi]
   unemulated protection
Stadium Cross [David Haywood]
   graphic problems, no controls
   src\drivers\multi32.c
HeadRusch
« Reply #13 on: June 11, 2003, 04:58:12 pm »
Poog's on fire ;)
rampy
  • *shrug*
« Reply #14 on: June 11, 2003, 06:18:49 pm »
are all those source diffs include/inclusive in mame. 70?
rampy
SirPoonga
  • Puck'em Up
« Reply #15 on: June 11, 2003, 11:52:22 pm »
rampy
inclusive of course.
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
« Reply #16 on: June 12, 2003, 01:37:50 am »
"8th June, 2003
More Zinc WIP.....
Wow!  Best.Fighter.Ever
-Ace-
I want my own arcade controls!
HeadRusch
« Reply #17 on: June 13, 2003, 11:11:14 am »
Sorry, this is SPAM from another thread I started..anyone else notice that you can no longer choose what resolution to default to??
What did they change? This was working in .68 for sure.....all I can select now for video mode is AUTO...I can't force a resolution like 800x600 anymore...meaning some games, like marvel super heros, for some reason stay centered in my screen...must be its native resolution.
Choosing STRETCH just stretches it horizontally, it does not stretch it vertically....which sux.....
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« Reply #18 on: June 13, 2003, 11:27:18 am »
sweet. virtua fighter.  :D
how soon will soul calibur be emu'd. i 4 1 would love to not have to hook my dc->vga cable up every time i feel the need to 'step into the next dimension' ;D
edit: oh yeah, what is zinc? ???
« Last Edit: June 13, 2003, 11:36:44 am by jakejake28 »
It's all about the Pentiums
SirPoonga
  • Puck'em Up
« Reply #19 on: June 13, 2003, 01:40:41 pm »
jakejake28
« Reply #20 on: June 13, 2003, 01:54:02 pm »
ooh la la ;D
