Author Topic: u360 / nulldc and joy2key  (Read 3271 times)
mrclean
    • Guscade
« on: August 28, 2008, 09:48:37 pm »
I'm getting an error that won't let me load nulldc it says "the application configuration is incorrect, try reinstalling" ?? I looked at the config file even tried to delete it still wont load *edit* fixed that.. btw the way i fixed the above error is i aparently needed to download the full install for my other computer i don't know why but should you run into this problem look for the "full setup" of nulldc it should be 3mb not 200kb a weird error.. but that seems to fix it...now onto u360's...
« Last Edit: August 29, 2008, 01:38:25 pm by mrclean »
2,370,650 Gun.Smoke
mrclean
    • Guscade
Re: nulldc error when transfering software from this computer to another
« Reply #1 on: August 29, 2008, 12:33:16 am »
ok don't know why it's running now, but how do i get my u360's to work with this emulator ?? well .. let's put it this way i used joy2key which worked however when i went in a random MAME game it was controlling all funky so i deleted all the setttings i made in joy2key what am i doing wrong? i don't want it to mess with my other emu's etc any way to have MaLa work around this and just utilize joy2key for this software and close it when i close the emu ??
« Last Edit: August 29, 2008, 01:39:25 pm by mrclean »
2,370,650 Gun.Smoke
SailorSat
  • Last login:September 09, 2026, 05:12:59 pm
    • For Amusement Only e.V.
Re: u360 / nulldc and joy2key
« Reply #2 on: August 29, 2008, 02:31:25 pm »
just use the joystick interface not the keyboard, that should to the trick.
the "configuration error" comes from a missing visual C runtime
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
mrclean
    • Guscade
« Reply #3 on: August 29, 2008, 03:37:41 pm »
? confused
2,370,650 Gun.Smoke
SailorSat
« Reply #4 on: August 29, 2008, 06:00:24 pm »
Ah nevermind, 1.0.3 droped support for gamepads (again)
