Author Topic: Any way to use both tree and non-tree navigation together?  (Read 2510 times)
Stobe
  • Trade Count: (+17)
« on: August 27, 2008, 03:51:55 pm »
I'm finally learning the brilliance of MalaTree, after using Mala for a long time.
But I was wondering, if you could have the whole thing setup in Tree mode, but still switch gamelists and emus from the arrow keys once inside a gamelist?
i.e., using Tree to navigate to Arcade -> Mame -> Classics
and then use Right Left to go to different lists,
and/or use Ctrl-Right/Ctrl-Left to switch Emus.
(The first of those two abilities being the more desired if I had to choose only one).
Thanks for any help,
Stobe
loadman
  • Moderator
  • Last login:May 02, 2026, 12:16:38 am
    • MaLa
Re: Any way to use both tree and non-tree navigation together?
« Reply #1 on: August 27, 2008, 07:24:59 pm »
I don't think so.
