Author Topic: My new mame project, the beginning  (Read 1762 times)
Axe
  • Last login:April 16, 2010, 11:16:05 am
« on: August 24, 2008, 08:42:13 am »
Hey guys,
Ia mr eady to start on my new Mame project.  I picked up a tekken 3 game (working) fairly cheap locally, by the description it was apparently a 27" showcase cab (a tight fit for our SUV) when i got there it was a 33" showcase!!!! No way in heck that would fit!
after much favour requesting and leg pulling the cab is at my brother in laws tonight and comng here tomorrow.  After playing a litle Tekken 3 on it yesterday, iam doubly sure i want to replace the sticks, and i need more buttons and want to add a trak-ball
SO, first issue, THE CP:
I am going to grab an Arcadevga card form andy (pci-e i hope, don't see it as a checkout option on ths ite right now) and was planning on a J-pac, BUT
After looking at the ultrastik 360, I think it may be a better choice. i can switch to 4 way operation through software, and the stick will always feel the same.
Heres my questions-
1- IS anyone using the arcadevga without the J-pac ona  large monitor like this?  I am unsure of the exact monitor, i should have more info later tonight...
2-  If I was planning to run 2 ultrastiks and a u-trak, would it make more sense to ditch the jamma harness, connect the 8 button set to each stick, and just run a USB-hub up to my CP area?
Pics should follow this evening... gonna try to document the experience.
Dave
Just when you thought you were out of Mame???
THEY PULL YOU BACK IN!
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: My new mame project, the beginning
« Reply #1 on: August 24, 2008, 09:55:22 am »
While I am a huge JPac fan, I think that you would be right to ditch the jamma harness in this instance.
Things to bear in mind are:
- you'll have to hack a VGA cable (or buy one of Andy's)
- you need to think about audio a bit -- the speakers in your cab are unamplified mono, so you'll need to add an amplifier of some flavour (or ignore the existing speakers and use amplified speakers)
Working: Not Enough
Projects: Too Many
Progress: None
moloch
  • Last login:June 29, 2022, 06:22:19 pm
  • I'm an ill'llama!
« Reply #2 on: August 24, 2008, 10:10:29 am »
In the project I am working on for a friend I ditched the Jamma harness and went with one of Andy's video amplifiers and an ArcadeVGA. It is the same circuit that is on the J-Pac to protect the monitor. It is only $21 if I remember and it will protect your monitor.
That is my $.02.
I have also tested the same system using soft 15 as well and it worked great. That little amp is worth the cost.
Axe
« Reply #3 on: August 24, 2008, 10:57:14 am »
I hadn't noticed that  video amp on Andy's site...  I would have ended up buying the J-pac, just for the amp   ::)    I think the ultra-stik and u-trak will be the way to go... and since they all support independant buttons, I shouldn't have need for any other interfaces.  If i go with a 5 or 7 way high speed hub, that will leave me with a few extra ports under the hood for usb drive, or a wireless xbox controller interface, in case i decide i want to have 4 players...
OH, and as i write this, an update frlom the home front, The cabinet is at my brothers, his buddy with a truck left early this morning, and nobody bothered to let him know they needed to deliver the cabinet here, so my project is  held off until a tuesday night start...
Guess it gives me time to rder stuff from Andy and rebuild my pc...
 8)
moloch
  • I'm an ill'llama!
« Reply #4 on: August 24, 2008, 11:00:46 am »
Axe
« Reply #5 on: August 24, 2008, 11:16:55 am »
THanks Moloch!  :notworthy:
