Author Topic: Wico leaf 8-way to 4-way question  (Read 3343 times)
Ginsu Victim
  • Last login:Today at 03:12:14 pm
  • Comanche, OK -- USA
« on: August 20, 2008, 02:48:55 pm »
I have an old panel that came with two 8-way Wico leaf joysticks. I was planning on cleaning them and reusing them, but I'd really like to convert one to a 4-way.
What are my options?
Re: Wico leaf 8-way to 4-way question
« Reply #1 on: August 20, 2008, 02:51:03 pm »
You'll need a new base. The gray one which has a diamond shaped restrictor. I suppose you could fabricate one.
I've got both the 4 ways, and 8 ways. Love'em.
Ginsu Victim
« Reply #2 on: August 20, 2008, 02:58:12 pm »
Thanks for the quick reply.
I've glanced around a few sites, but haven't found any bases (not even knock-offs).
I'm not sure I have what I need to mock up my own.
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
« Reply #3 on: September 20, 2008, 04:05:57 pm »
You may not need the entire base, just a 4-way actuator?   Got a picture of your stick from the bottom?
« Reply #4 on: September 20, 2008, 05:24:19 pm »
From: http://www.mameworld.net/massive/How-to/Wico/wico.htm
The difference between a 4-way wico stick and an 8-way?  The 4-way has a diamond shaped washer embedded in the mounting plate, the 8 way is round. This restricts the movement of the shaft, and ensures that the sleeve only contacts one leaf switch at a time.
pcb
    • MikesArcade.com
« Reply #5 on: September 20, 2008, 07:06:06 pm »
404: Fixed URL is:
http://www.mameworld.net/massive/How-to/Wico/wico.html
Yup, I'm aware of that, however, he could still just need to change the actuator.  Both of these work on a 4-way Wico base to make a 4 or 8 way stick.
« Reply #6 on: September 20, 2008, 07:13:19 pm »
Thanks for the URL fix.
This is true, you'll need the different actuator and you may be satisfied with the results. The problem is the dead zones. Sure, you could bend the leafs to try to minimize the dead zones, but since your looking to change a 8 way to a 4 way I'm willing to bet you won't be happy unless you swap out the base and have a physically restricted 4 way.
Since your going to need the actuator anyways - you might as well try it with just the actuator and then look for a base. I found a replacement actuator at Home Depot.
pcb
    • MikesArcade.com
« Reply #7 on: September 20, 2008, 07:59:27 pm »
Very cool!  Care to share exactly what you used as the 4-way actuator?
 - Mike -
« Reply #8 on: September 20, 2008, 08:03:42 pm »
 - Mike -
From this thread
http://forum.arcadecontrols.com/index.php?topic=48053.0
It's a 1/2" outer diameter. If I remember correctly, I had to go to 2 different Home Depots. And bring the joystick to make sure the spacer fits the stick.
pcb
    • MikesArcade.com
« Reply #9 on: September 20, 2008, 09:32:14 pm »
Ginsu Victim
« Reply #10 on: September 20, 2008, 09:54:54 pm »
Month-old thread I don't even care about anymore. :)
Thanks for trying, though. I gave my Wico to mrclean for a restoration.
« Reply #11 on: September 20, 2008, 11:13:44 pm »
Psst, guess what - other people read these threads.
Ginsu Victim
« Reply #12 on: September 21, 2008, 12:50:39 am »
Well, yeah. There's some great info here, I just meant that it wasn't going to do ME any good at this point.
Texasmame
  • No, no. He's in charge here.
  • Last login:February 18, 2022, 05:28:39 pm
  • Ba, ba, boom!
« Reply #13 on: November 11, 2008, 02:51:11 pm »
*helpful thread bump*
Ginsu Victim
« Reply #14 on: November 11, 2008, 07:41:45 pm »
Why you bumpin' my thread? ;)
Texasmame
  • Ba, ba, boom!
« Reply #15 on: November 11, 2008, 09:09:19 pm »
The pic of the diamond restrictor plate gave me the answer, and an idea, I was looking for.   :notworthy:
