Author Topic: T-Molding cutter help!  (Read 3625 times)
ratzz
« on: August 17, 2008, 02:24:46 pm »
Hi Guys,
Can someone help me with my purchase of my slot cutter?
I'm planning to get the below blue t-molding, but need the cutter as well, but I'm lost on which one I need.
Can someone take a look for me at the site below and advise me?
Blue T-Molding: http://www.t-molding.com/store/product.php?productid=27&cat=9&page=1
Thanks chaps,
miles2912
Re: T-Molding cutter help!
« Reply #1 on: August 17, 2008, 02:37:09 pm »
Did you see this this page and read it?
http://www.t-molding.com/store/home.php?cat=6
It tells you what slot cutter fits what t-molding.
Franco B
« Reply #2 on: August 17, 2008, 02:39:53 pm »
Hey ratzz,
The webbed section on that t-moulding is 3/32" which is 2.38mm. You want a slightly smaller kerf on your t-slotter so that the t-moulding grips the sides of the slot. I would suggest a 2mm slotter like this one from tooled-up.com. Click the pic for the link.
Franco B
« Reply #3 on: August 17, 2008, 02:46:06 pm »
Looks like we replied at the same time.
After reading the post above it seems they suggest a 1/16" cutter (1.6mm). Personally, speaking from experience you don't want to route a slot too small if the slot is close to an edge especially if you are using MDF as the force of installing the t-moulding into a tight slot can cause the wood to split.
I'm guessing a 1/16" cutter is the nearest imperial width cutter available 'over the pond'. If it was me, I would go with the 2mm.
ratzz
« Reply #4 on: August 17, 2008, 03:37:10 pm »
Yes, but I've just realised that I miss-read the chart at the bottom.
Thanks for your help guys...
ratzz
« Reply #5 on: August 17, 2008, 03:38:34 pm »
Hey ratzz,
Thanks Franco -- been looking in the UK for these ...
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
« Reply #6 on: August 18, 2008, 10:46:05 am »
If you can't find them locally, Holbren ships internationally. It cost $8 to ship a $19 Whiteside 1/16" slot cutter to Canada.
