Author Topic: How to bypass overvoltage protection - U2000/U5000/k7400/k7500  (Read 2388 times)
castlesteve
  • Last login:September 12, 2014, 09:10:32 am
  • uh, yea
Can anyone give me a hint on how to temporarily bypass the overvoltage protection circuit on these boards?  This circuit is identical for all of U2000, U5000, k7400 and k7500 boards.  I just need to test a theory as I believe it is stuck on and preventing the following circuit from turning on (oscillating correctly) Q703 -> transformer -> HOT -> flyback
I searched and searched and couldnt find a link to it... but i know ive read about it before somewhere.
Thanks,
Steve
sarge
  • Last login:April 27, 2015, 01:42:54 pm
Re: How to bypass overvoltage protection - U2000/U5000/k7400/k7500
« Reply #1 on: August 14, 2008, 06:36:14 pm »
What makes you think that it's not shutting down for a reason?  Can you give a little more specific information as to what you are repairing and/or what you have already done?
castlesteve
  • uh, yea
« Reply #2 on: August 14, 2008, 07:03:09 pm »
I've repaired dozens of these boards and have never seen this kind of failure.   Without going into detail about my history or etc, assume I've covered all the standard tests.   I have 15 years of EE experience... But would like to know the proper way to disable this feature.
smartbomb2084
  • Last login:January 13, 2021, 03:14:53 pm
  • Having a SMART phone will make you DUMB.
« Reply #3 on: August 16, 2008, 12:32:30 am »
Can this even be done?  Isn't the overvoltage protection circuit part of the power supply controller UC3842A?  Pin 3 is the SENSE input and pin 2 is connected to the power supply output.  Small elctrolytics ( like C117 on a U5000 ) can cause the sensing circuit and feedback circuit to malfunction making the controller think there is a problem.
