Author Topic: Wiring my first JAMMA harness and have a question........  (Read 1812 times)
pharoah007
  • Last login:June 29, 2017, 07:27:26 pm
  • Why buy it when you can BUILD it!
« on: August 13, 2008, 10:39:01 am »
so the bottom 3 terminals in the pic are for the monitor as I understand it.
so the Ground wires on the JAMMA harness go to the COM on the power supply?  and if so, which COM as there are 2 of them?
Here is a pic of the PS in question..
http://i4.photobucket.com/albums/y145/pharoah007/DSC04221.jpg
thanks everyone. :cheers:
pharoah007
Re: Wiring my first JAMMA harness and have a question........
« Reply #1 on: August 13, 2008, 04:16:13 pm »
hummm no replies...
Is this info in the FAQ or a sticky?? I have been looking and have not come across it.
Thanks all
2600
« Reply #2 on: August 13, 2008, 04:20:14 pm »
1. Yes, GND goes to COM.
2. Pick one.
I'd use a multimeter to check that they are the same, but I imagine they are.
pharoah007
« Reply #3 on: August 13, 2008, 04:27:52 pm »
2. Pick one.
thanks man. so can I wire ALL of the grounds on the JAMMA harness to 1 of the ground terminals?
or should I wire all the grounds on the JAMMA harness to the 2 ground terminals (1/2 to 1 and 1/2 to another)?
2600
« Reply #4 on: August 13, 2008, 04:52:03 pm »
Usually, you just wire up the 4 Ground next to the power pins on a Jamma connector to the Power Supply.  Depending how what I had available, I'd wire it up using 1 terminal or both terminals.
Read this to learn about the other grounds:
http://therealbobroberts.net/jh.html
