Author Topic: games list  (Read 2784 times)
G1zm0
  • Last login:October 05, 2020, 06:57:58 am
  • cute by day, devil by night
games list
« on: August 11, 2008, 06:06:40 pm »
ive put mala games list in mala but do i need to add all the vertical games i want to run to it?
or is there a way it can do it itsself?
how do i get mala to ignore things like dups and things in brackets ect like set 1, sega , biitleg ect?
i want mala so it shows only vertical games with no dupes and just games names.
ive made a list with romlister but when i point mala to the file it shows as all roms (with horisontal games in it)
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Re: games list
« Reply #1 on: August 11, 2008, 06:52:18 pm »
ok, I really want to help with your issues with romlister, but you keep moving the discussion thread around on me! ;)
Steps to make a MALA list in romlister build 13 with only vertical games:
1) start romlister.
2) open tools and settings and build a merged file.  Tutorial is here: http://wiki.arcadecontrols.com/wiki/RL_tutorial_merge
3) check the "vertical only" checkbox under monitor orientation.
4) press the "go!" button. - after a bit the "working list" dialog will appear with your roms in them.  Do a casual search through there to see if you can find any known horizontal games.  If you do, then there is something wrong and you should post the text from your -find window here for me to see it.
5) In the "working list" window, select mala gamelist in the dropdown box and press "save list to file"
6) a popup window appears asking for a name - give the list a unique title
7) select a file to save your list to.  Save it in your mala folder.
Now, in your mala folder, you should see a program called "malagamelist.exe"  launch that.
1) open the file you just created with romlister.
2) click on gamelist
3) go down to "remove brackets from name->All"  the rom names should now be cleaned up.
4) save the list and exit.
Now launch Mala
1) right click on the mala screen->select game list
2) find your new list there, and select it.
tada!
it does work-really.  I'm using romlister and mala and I have a vertical cab, and I just followed these steps and it worked as well as could be expected.
If you get different results, please post your exact details.
-jeff!
edit: changed "without vertical" to "only vertical"  oops!
« Last Edit: August 15, 2008, 10:52:05 am by NOP »
Paul Olson
    • Paul's Arcade
Re: games list
« Reply #2 on: August 14, 2008, 07:30:19 pm »
I made a bunch of gamelists in romlister and stored them in a gamelist folder. Even though I set the directory in mala tree, it apparently didn't see the lists. All of my gamelists showed all games in Mala. I put the lists in the mala folder, and they work fine. I haven't had time to test it more to try to figure out the problem. If your gamelist is not in the mala root folder, try moving it there.
G1zm0
Re: games list
« Reply #3 on: August 15, 2008, 04:49:46 pm »
thanx nop and pcolson, got it working
