Author Topic: Has anyone buffed scuffs/scratches out of brushed aluminum?  (Read 1601 times)
shmokes
  • Don't tread on me.
    • Jake Moses
« on: August 11, 2008, 01:59:32 pm »
My control panel surfaces are brushed aluminum and they have a couple scuffs in them.  Does anyone know how I can make them disappear?
Best Kid iPad Apps
extendedplayarcade
  • The Games You Crave
    • Extended Play Arcade
Re: Has anyone buffed scuffs/scratches out of brushed aluminum?
« Reply #1 on: August 11, 2008, 03:01:00 pm »
http://www.amazon.com/Metal-Polish-Cream-3-5-tube/dp/B000ID0H7K/ref=pd_bbs_sr_2?ie=UTF8&s=automotive&qid=1218481090&sr=8-2
This Stuff "blue Magic" works great on metal, plexi glass, lexan.
You should see what it does with Chrome.  It is like am mirror finish.
Even old Silverware makes it shine.
wow i sound like an infomercial hahhahaha  :soapbox:
Anyways I been using this stuff for over a decade.
Brent
www.extendedplayarcade.com
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
« Reply #2 on: August 11, 2008, 07:46:50 pm »
Are you talking about some minor surface scuffs or scratches/gouges?
For very fine abrasions, there are synthetic pads, like Scotch-brite pads,
made to be used in place of fine steel wool.  I've had good luck with
some i picked up at Canadian Tire.  You may be able to find some
at Home Depot or other hardware stores.
Edit:
Whatever you use, go gently. As you've discovered, aluminum is
very easy to abrade.
« Last Edit: August 11, 2008, 07:57:09 pm by EwJ »
ark_ader
  • I glow in the dark.
« Reply #3 on: August 12, 2008, 06:57:57 pm »
Ajax.
