Author Topic: Drilling through diamond plate  (Read 8832 times)
shmokes
  • Don't tread on me.
    • Jake Moses
« on: August 10, 2008, 07:06:05 pm »
You know that stuff that owners of old jeeps put on the corners to cover up rust?  Well, I have a 1/8" thick sheet of it that I'm using for a component in my cab and I'll be damned if it isn't the hardest substance on earth.  I'm using a fairly decent corded drill and I just drill and drill and drill and barely make any progress.  Maybe I need to go pick up a cobalt bit or something.  I haven't even finished one hole yet and I need to make about 10 more.
Best Kid iPad Apps
somunny
  • Is it hot in here?
Re: Drilling through diamond plate
« Reply #1 on: August 10, 2008, 08:46:10 pm »
Sounds like your bit is dull.  Go buy some good bits.  I would think high speed steel would be sufficient enough for what you're drilling but you may want to buy cobalt bits.  Also, I'd recommend marking each hole with a center punch before drilling (if you're not already).
edit:  Is it stainless diamond plate?  SS is not magnetic if you want to check.
shmokes
    • Jake Moses
« Reply #2 on: August 10, 2008, 08:51:19 pm »
Bit was dull.   :-[
After one and a half holes, which took an ungodly amount of time, the bit snapped.  So I popped in another identical bit (my bit set came with thee 1/8" bits) and in less time then the first one and a half I drilled the other nine and a half holes.   ;D  Live and learn.
Best Kid iPad Apps
Blanka
« Reply #3 on: August 11, 2008, 02:22:28 am »
Next time make a .dwg and have it water-cut!
