Author Topic: When is joystick recess routing necessary?  (Read 2092 times)
TheGameAh
  • Last login:June 09, 2004, 10:52:01 am
  • You are not FreakZilla.
    • Arcade Cab
« on: June 09, 2003, 07:58:03 am »
Hey guys.  I'm getting ready to build another control panel out of 3/4" MDF.  I'd like to lay a sheet of 1/8" plexiglass over top of that.  I got some Ultimate joysticks from Happs on the way.  Will it be necessary to recess route?  If that's the case, could I get by with 1/2" MDF?  I really don't want to recess route  :)
Chris
    • Chris's MAME Cabinet
Re:When is joystick recess routing necessary?
« Reply #1 on: June 09, 2003, 09:01:58 am »
I used 5/8" MDF with 1/8" Lexan and I didn't need to recess the joysticks.
--Chris
--Chris
HeadRusch
  • Last login:September 02, 2006, 04:13:30 pm
  • ....Here you are all EQUALLY WORTHLESS...
« Reply #2 on: June 09, 2003, 09:24:05 am »
Its really a personal preference.  I used 3/4" MDF and 1/8" Lexan on my CP....my joysticks are a bit on the stubby side but frankly I like them that way...I dont like really tall sticks.
Nbody has yet to complain that the joysticks are too small...on the otherhand, I haven't had any hard-core fighter players over...they'd probably ---smurfette--- and moan about the joysticks not being 5 inches tall or whatever.
".....its like a Koala crapped a rainbow in my brain!"
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: June 09, 2003, 11:23:37 am »
if you plan on using restrictor plates too you will problably want to recess.
Generic Eric
« Reply #4 on: June 09, 2003, 04:00:24 pm »
You should wait untill you get all your parts, then start building.  That way you can be sure you are only routing away what you need to.
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
« Reply #5 on: June 09, 2003, 04:17:12 pm »
The HAPP Ultiumate Joysticks allow you two heights using a provided spacer (one about 1/2 longer than the other).  As someone said above, if you are using restrictor plates as well, which add about 1/4 inch you would really need to route a 3/4 MFD.  If you aren't using restrictor then you should be fine not routing the 3/4 and using the joystick at it's longer length (if you go with HAPPS).
:) Rotate or die! :)
