Author Topic: Hantrax monitor  (Read 4077 times)
neil324
  • Last login:October 07, 2013, 03:53:50 am
Hantrax monitor
« on: August 07, 2008, 10:16:05 am »
My arcade monitor is starting to sometimes lose it picture. When i adjust the pots V/sync Hsync etc it can lose the picture on the screen totally or almost. But when you touch the adjustment screw without turning it,it comes back on. Its also worse when the monitor has just been turned on.
Was thinking maybe the screws are a bit lose, but cant see a way of tightening them :dizzy:
I had'nt used the machine for a while and when i did, i had to do a lot of adjusting with the pots and when i did the was big sparks on the back of the monitor/loud cracking noises. Although its stopped doing this now.
2 pics of the chassis added, not sure if it is a hantrax, was told when i bought the macine it was.
« Last Edit: August 07, 2008, 10:40:26 am by neil324 »
neil324
Re: Hantrax monitor
« Reply #1 on: August 07, 2008, 11:48:16 am »
Ok just found out its a Kortex ktm20
gokun
  • Last login:March 26, 2014, 04:57:18 pm
Re: Hantrax monitor
« Reply #2 on: August 08, 2008, 12:37:45 pm »
any idea what part(or nearabouts) sparked and hissed on you? That is generally a very bad sign...anyways, let us know...
neil324
Re: Hantrax monitor
« Reply #3 on: August 08, 2008, 02:19:22 pm »
On the back of the monitor itself from the tube to where the cable/cap it fitted to the monitor. I had my hands inside messing with the pots etc  :dizzy: Altought its never done it since.
grantspain
  • Last login:Yesterday at 03:37:21 am
Re: Hantrax monitor
« Reply #4 on: August 08, 2008, 02:26:44 pm »
could be just damp and arcing from under the anode cap,if its coming from the flyback transformer it could be trouble
a bit of advice mate,don't under estimate the shock you will get from that arcing-probably 22000 volts-be careful
neil324
Re: Hantrax monitor
« Reply #5 on: August 08, 2008, 04:25:17 pm »
Does the anode cap sit on the back of the monitor, look like a big round sucker thing with the cable coming from the middle of. If so thats where the spark was going to/coming from.
Thanks for the advice. I did ---Cleveland steamer--- myself had visions of the sparks jumping out to me and turned it off from the mains ASAP.
The machine has not been stored in a damp room, but had'nt been turned on for 10 months maybe.
« Last Edit: August 08, 2008, 04:28:32 pm by neil324 »
grantspain
Re: Hantrax monitor
« Reply #6 on: August 08, 2008, 04:30:36 pm »
the suction cap is known as the anode cap,if a monitor is a little damp that is where it will arc from
you can either wait for the monitor to dry to room temp or you can clean the anode cap and the tube,judging from what you are saying i would choose the first option
neil324
Re: Hantrax monitor
« Reply #7 on: August 08, 2008, 04:36:29 pm »
Ok just looked at some flyback transformers. Looks to me like it was coming from the cap of the flyback that is conected to the monitor screen.
Its not doing it now, just like to now what the problem was for future ref, so i don't kill myself
Pic attached was defo coming from the cap
« Last Edit: August 08, 2008, 04:39:41 pm by neil324 »
grantspain
Re: Hantrax monitor
« Reply #8 on: August 08, 2008, 04:40:18 pm »
you do have this in a dry place
neil324
Re: Hantrax monitor
« Reply #9 on: August 08, 2008, 04:53:02 pm »
Yeh its my bedroom. Its summer time in the the uk so its humid too :laugh2: not to much though.
When i turned on the machine it was ok. It only started sparking when i messed about with the pots,felt like maybe i was pushing it to far. Not sure.
« Last Edit: August 08, 2008, 04:56:06 pm by neil324 »
grantspain
Re: Hantrax monitor
« Reply #10 on: August 08, 2008, 04:55:55 pm »
u.k,i bet its peeing down mate ;)
give it another 6 hours then try it again,if its still arcing i can guide you how to clean the anode area without hurting yourself
neil324
Re: Hantrax monitor
« Reply #11 on: August 08, 2008, 04:57:15 pm »
Ok thanks
