Author Topic: Vertical cab nightmares :(  (Read 9635 times)
nullb0y
  • Slow In Fast Out
    • WAT Racing
Re: Vertical cab nightmares :(
« Reply #40 on: August 20, 2008, 09:30:44 pm »
I might downgrade my mame
I only need it for vert games... and alot of the newer stuff doesnt emulate properly anyways
im going to get a .95 set and mess with that
It should run faster right??? lol
how would i remove the splash screens and add in hi scores to .95?
« Last Edit: August 20, 2008, 11:28:08 pm by nullb0y »
Slow In Fast Out
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #41 on: August 21, 2008, 03:59:16 am »
for splash screen try to put that behing your mame.exe  (if you are still using Atomic)
Look the Default Emulator field in AtomicManager.
you should have something like
Code: [Select]
c:\mame\mame.exe
just behind mame.exe  add   -skip_gameinfo  -skip_disclaimer  , to have :
Code: [Select]
c:\mame\mame.exe  -skip_gameinfo  -skip_disclaimer
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #42 on: August 21, 2008, 06:41:44 pm »
cool,
Well i got a pentium 4 2.4ghz with about 800 megs of ram (512+ 2x128) for $10
So, i will probably just use that thing in the cab
awesome news
It supports screen flipping and has 96 megs of onboard video ram??(64+32???)
intel has some weird chipsets (intel extreme graphics 2)
how do i get the computer power button to make xp shut down rather then open the shutdown dialogue?
« Last Edit: August 21, 2008, 07:02:06 pm by nullb0y »
Slow In Fast Out
youki
    • Atomic Front End
« Reply #43 on: August 22, 2008, 03:35:00 am »
You know in Atomic there is an option that when you quit Atomic it shutdown you PC Automatically. (just a check box to tick on the General Tab of Atomic Manager).
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #44 on: August 23, 2008, 01:24:36 pm »
Okay, its working great
And the internal speaker of the computer
is louder then the 2 speakers i was using lol
Question: how do i get atomic FE to play random music from a folder when its at the game select menu?
Slow In Fast Out
youki
    • Atomic Front End
« Reply #45 on: August 23, 2008, 05:48:49 pm »
You have plug'ins to do that .
called :  simple shuffle mp3 background.atoplug
You have to activate this plug'ins with AtomicManager (on advanced tab, plug'ins subtab) for your CFG.
You have to put all your mp3 you want atomic use in the folder of your Layout .
You may have to disable also the option "Enable layout's background music fi available" on option tab /option 1 subtab.  To avoid "conflict".
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #46 on: August 30, 2008, 01:34:18 pm »
Ill have to give that a try,
Everything is running great now
I do need to edit the game list
right now i have EVERY game listed lol
Slow In Fast Out
