Author Topic: Playchoice 10 monitor dim screen\ how to fix?  (Read 2835 times)
robrose77
  • Last login:August 05, 2008, 07:50:09 pm
« on: August 04, 2008, 07:05:27 pm »
I have a playchoice 10 dual screen arcade cabinet both screens work but the one that displays the game is dim...particulary dark greens which look black, but all in all the whole screen just isnt bright.  I have tried swapping the two screens only to have the dim one not even display anything when i moved it up top.  Doesnt sound like a cap kit would fix this but then again i dont know...i need suggestions
thanks
Rob
grantspain
Re: Playchoice 10 monitor dim screen\ how to fix?
« Reply #1 on: August 05, 2008, 02:38:46 am »
have you actually tried adjusting the colours/brightness and contrast yet?
robrose77
« Reply #2 on: August 05, 2008, 08:53:44 am »
of course....everything is turned all the way up on brightness.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: August 05, 2008, 10:21:28 am »
And that includes the other brightness control on the monitor main board? You also turned up the "screen" control on the flyback?
If that's the case then install a capkit.
grantspain
« Reply #4 on: August 05, 2008, 01:20:47 pm »
what monitor are you talking about,in the u.k pc10 had hantarex mtc9000
robrose77
« Reply #5 on: August 05, 2008, 07:04:54 pm »
Im only familiar with one brightness control on my monitor, i believe its a sanyo 20ez.  I adjusted the obvious one on the back of the monitor which the manual had as brightness...indeed it did control the brightness.  I am unfamiliar with one on the board...the manual didnt list another brightness control....so where is this thing?
robrose77
« Reply #6 on: August 05, 2008, 07:18:58 pm »
it appears i have type 35 or 20-z2aw playchoice 10 monitor it has the typical controls on the bottom of the unit (v-hold, h-cent, bright, v-size, volume....in another location it has a knob for R, G, B
