Author Topic: Enabling mouse in mame  (Read 1265 times)
heinekenlvr
  • Last login:January 19, 2022, 01:27:17 pm
« on: August 04, 2008, 11:06:38 am »
Hi All,
I need help enabling my mouse in mame v.100. First, I tried to create a mame.ini file but it didn't work. I went to 'run' and typed mame -createconfig. I looked in the mame directory and I still don't see the mame.ini file. Second, I assume that once I create the ini file, I need to turn the mouse on? I really could use your help as this is quite frustrating. Thanks.
heinekenlvr
Re: no left or right mouse control
« Reply #1 on: August 04, 2008, 12:32:11 pm »
 Ok so after a little fiddling I created a mame.ini file. I changed the mouse settings from 0 to 1 and saved the changes. I reloaded Atomic and loaded Pole Position 2. Aha, partial success. The mouse keys work fine but I have no left or right movement (I also tried moving the mouse up and down without success). I hit TAB to try and change the game settings but the mouse is not one of the options to move left or right. I currently have a OPTIPAC running a steering wheel (which runs fine outside of mame). Here is a copy of my controller settings:
### Input device options ###
mouse                   1
joystick                0
lightgun                0
dual_lightgun           0
offscreen_reload        0
steadykey               0
keyboard_leds           1
led_mode                ps/2
a2d_deadzone            0.300000
# ctrlr                 <NULL> (not set)
paddle_device           keyboard
adstick_device          keyboard
pedal_device            keyboard
dial_device             keyboard
trackball_device        keyboard
lightgun_device         keyboard
digital                 none
Thanks for the help.
ahofle
    • Arcade Ambience Project
Re: Enabling mouse in mame
« Reply #2 on: August 04, 2008, 01:18:45 pm »
Maybe try changing 'paddle_device' and 'dial_device' to 'mouse'.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: August 04, 2008, 07:46:59 pm »
Nah, that does the same thing.  (differences not important for this thread, unless anyone's curious.)
OP, I'd make sure -multimouse is still disabled (0).  If that doesn't help, try remapping: tab, "Input (this game)", scroll down to "dial analog", press enter, spin wheel, wait and see if it's mapped.  (If not, try different spin speeds.)  IIRC, you said the wheel works in windows, or am I confusing with a different person?
Robin
Knowledge is Power
