Author Topic: Software for designing control panels  (Read 3998 times)
codenamed
  • Last login:January 06, 2012, 12:46:04 pm
« on: August 02, 2008, 03:23:51 pm »
I was told by a user on klov.com that there is software for designing Control panels. Anyone know if this is true and have a link?
Paulson
  • Last login:January 29, 2015, 06:55:37 am
Re: Software for designing control panels
« Reply #1 on: August 02, 2008, 11:27:18 pm »
 Well theres this from Ultimarc: http://www.ultimarc.com/download.html
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #2 on: August 03, 2008, 12:38:23 am »
And there's Microsoft Visio.  Users have made stencils for just about every control ever made which can be downloaded and then drag/dropped onto your page.  I printed out my visio drawings, taped them to my control panel and voila.  Made all my marks from that and drilled away.
Best Kid iPad Apps
Encryptor
  • Trade Count: (+34)
« Reply #3 on: August 03, 2008, 08:44:19 am »
Here is one from mameroom.com that is pretty good.
http://www.mameroom.com/files/mameroomcpd.zip
Encryptor
facesmiths
  • Last login:April 10, 2011, 07:53:05 pm
  • nemo goggles
    • Borg Steam Factory
« Reply #4 on: August 04, 2008, 05:45:35 am »
wow and I just used a micrometer to measure out my controls and then used coreldraw.
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
« Reply #5 on: August 04, 2008, 08:49:16 pm »
GAtekwriter
  • Last login:July 16, 2011, 09:55:44 am
« Reply #6 on: August 06, 2008, 05:21:12 pm »
I wrote a brief tutorial on using Inkscape to create your own CP template and overlay:
http://forum.arcadecontrols.com/index.php?topic=82525.0
kayoteq
  • Last login:May 28, 2022, 02:15:51 pm
    • Webmonkees arcade bin
« Reply #7 on: August 08, 2008, 12:49:24 am »
My approach is a bit reversed, different problem;
 instead of blank, I'm having to adapt two panels that have been imprecisely drilled for a conversion.
That won't quite work with the programs that are expecting straight lines, so I use Illustrator/photoshop.
I empty the panel, take as straight-on a picture as possible..
In my case, I got the appropriate art file for my game from localarcade.. so I have at least some holes to scale to and match positions.
Then I make some elements that match the holes, remove the photograph,
Then design around the existing holes,  fill in the extra holes once I get a design that works well. Helps  a bit to  work from the same
template as your original panel.. which isn't always the case.
If you order a pizza, put 1 quarter in their Galaga and the pizza's done before you are, you might be a video game junkie.. if you offer to tweak the crt , definitely.
