Author Topic: Problem With U360 sticks & NullDC  (Read 3163 times)
lettuce
  • Make It So!
« on: August 02, 2008, 01:59:34 pm »
Am trying to get my U360 sticks to work correctly with NullDC. I have configured the button layout with the U360 in the 'maple' settings within NullDC and everything seems fine. But when i load a game, then the sticks are acting up, jumping all over the place and jittering about, for instance on a VMU select screen for Under Defeat, the curser for the selecting a VMU slot would be going all over the place. Any ideas at how to sort this problem out??
lettuce
  • Make It So!
Re: Problem With U360 sticks & NullDC
« Reply #1 on: August 02, 2008, 07:25:19 pm »
anyone?
fjl
  • Pixels Rule!
« Reply #2 on: August 02, 2008, 08:03:33 pm »
Are you by any chance playing with the sticks while loading NullDC? Holding a stick while booting up a game system usually causes the position of the stick to act as default center position, obviously causing problems.
If you're not touching the sticks, check Windows Game Controllers, select the U360 and view the properties. If the joystick is acting up then the stick is bad. If not, then something is off with the emulator. Try checking the properties after running NullDC just to see what happens.
lettuce
  • Make It So!
« Reply #3 on: August 03, 2008, 04:30:37 am »
Nah im not touching the sticks when NullDC is loading, and the sticks are centered correctly when view them throught the U360 mapping program and gamepad settings in control panel. Any suggestions what might be causing NullDC to do this, there is only one joystick plug-in i can use, so it not like i can select a different controller plug-in to try.
When i config the joystick buttons in NullDC settings, and pressing the inputs for the joystick configs its doesnt seem to give me any problems there, i have press 'enter' on say input for 'right', and left the joystick well alone and it has selected another input itself, so i dont think the stick is playing up at that point otherwise it would have selected an input as it would be jumping about all over the place.
fjl
  • Pixels Rule!
« Reply #4 on: August 03, 2008, 01:24:02 pm »
This seems like a pretty weird problem. Does NullDC have its own forums? If so you should ask there. Unless you already have.
