Author Topic: Cab friendly console emulators  (Read 2871 times)
bent98
  • Last login:February 02, 2019, 03:35:00 pm
  • Hyperspin Moderator
« on: August 02, 2008, 09:30:17 am »
Can anyone tell me what NES,SNES,SEGA, Atari emulators I can use for my cabinet via Mala FE. My exit is mapped to ESC and I need something that will allow my cabinet and FE to function as Mame does.
amiga500
  • Last login:December 29, 2024, 10:09:10 pm
Re: Cab friendly console emulators
« Reply #1 on: August 04, 2008, 11:32:51 pm »
I have snes and atari emulators on my cab, besides zinc and mame of course.
For Atari I have z26 and for Snes I don't remeber if it is znes or snes9x, I remember I had issues with one of them, but the other is ok, download here: http://www.romnation.net/srv/emulators/snes.html
cheers :cheers:
bent98
« Reply #2 on: August 05, 2008, 08:49:06 am »
I tried that version of snes. Esc doesnt exit emulator.
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
« Reply #3 on: August 05, 2008, 09:05:20 am »
You can force any emulator to exit via the Esc key by using the Hot Key functionality in MaLa.  In fact, if all you want it to exit, just check the box "Exit Hook" on the "Other Emu" configuration screen and that will do the trick.
For NES, I'm using Nestopia which is highly regarded as one of the most accurate.  It happens to support very flexible key remapping.
For SNES, I use ZSNES, also very flexible.  If you add the parameter -m to the command line, then it by passess the built-in GUI and will exit by pressing Esc.
For 2600, Stella is at the top with MESS and is highly configurable as well.
I don't use a Sega Genesis or Master System emulator but I hear Kega Fusion is one of the best.
"The Manuel"
bent98
« Reply #4 on: August 05, 2008, 12:46:34 pm »
Can you paste you mala config for those emu's.
Also do you know how to config Mala to launch PC games from a list?
TheManuel
« Reply #5 on: August 05, 2008, 02:02:41 pm »
OK.  When I get home, then.
They're squeezing my nuts here at work today.
"The Manuel"
bent98
« Reply #6 on: August 05, 2008, 03:42:11 pm »
Must be a nice line of work your in?
TheManuel
« Reply #7 on: August 05, 2008, 04:43:11 pm »
 :cry:
"The Manuel"
deadsoulz
  • Last login:December 19, 2023, 02:24:28 pm
« Reply #8 on: August 07, 2008, 09:50:52 am »
zsnes will exit by hitting the escape button.  You need to edit the cfg file and set the NO GUI or GUI OFF=1 or something like that.  I reccomend this one.   Nestopia or FCE for nes works great.
Fusion works well for sega genesis.
