Author Topic: 3m Touch Monitor  (Read 1920 times)
Oldtimehockey
  • Last login:September 01, 2008, 01:51:30 pm
3m Touch Monitor
« on: August 01, 2008, 09:34:37 pm »
Hi, I'm looking to purchase a touchscreen Monitor for a Jukebox project. I've found the following monitors.
Has anybody used these? Are they a pain?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=280251842121&ssPageName=STRK:MEWA:IT&ih=018
They're 3m Monitors
kayoteq
  • Last login:May 28, 2022, 02:15:51 pm
    • Webmonkees arcade bin
Re: 3m Touch Monitor
« Reply #1 on: August 09, 2008, 01:56:59 pm »
I"ve put in a few systems using touchscreens; they're generally quite durable, being made for point-of-sale systems mostly, most use a mouse driver for Win98/2000/XP and plug in either by USB or a mouse port. If they fail calibration, though, it's pretty much done for except as just a display. I've only have one or two actually fail calibration, though. Calibration, in this case, is just a series of targets you hit with your finger to line up the system.  The failure is something to do with the geometry failing to map out the whole screen consistently; the top half lines up, the bottom goes all over the place..
The newer you get, the better, as the quality has improved over time. ELO touchsystems are the ones I mostly encounter, but any number of manufacturers can be involved in the components themselves.
If you order a pizza, put 1 quarter in their Galaga and the pizza's done before you are, you might be a video game junkie.. if you offer to tweak the crt , definitely.
Oldtimehockey
« Reply #2 on: August 10, 2008, 10:04:59 am »
Thanks Kayotec, I actually went with a ELO
