Author Topic: dead zone on volume control  (Read 1503 times)
Breaker
  • Last login:December 10, 2024, 11:38:20 am
« on: July 30, 2008, 10:47:31 am »
Hello all,
I'm hoping some electronics gurus might be able to assist with a small issue I'm having with my volume control.
I installed a remote volume control to my CAB's control panel using the method described at the old Oscar Controls website:
http://mirrors.arcadecontrols.com/OscarControls/volume/index.shtml
The potentiometer I used (100k as per the tutorial) has approximately 270 degrees of rotation and the volume jumps rather sharply in the first 10-15 degrees of rotation and again in the last 10-15 degrees but in between there is a rather large 'dead zone' where there is no effect on the CAB's volume. I did read that you could increase the sensitivity of potentiometers by adding resistors across the terminals, which I have tried, but this didn't have any effect. Do I need to use a different potentiometer (10K, 50K)? Have I possibly wired it incorrectly? I don't know if it's relevant but I'm using Logitech Z4 speakers.
Any assistance would be greatly appreciated.
Cheers,
Breaker.
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
Re: dead zone on volume control
« Reply #1 on: July 30, 2008, 10:57:24 am »
Howdy
First of all, are you usig a linear pot instead of a logarithmic?
You also say that you're putting a resistor across the terminals... It would need to be in-line with the wiper. So removing the wiper (usually center) wire and putting the resistor in series. Putting a resistor across the terminals will only decrease the resistance.
Breaker
« Reply #2 on: July 30, 2008, 09:12:39 pm »
Hi ST,
I'm using a logarithmic pot and, I should clarify that I'm not employing resistors, just gave them a try but they had no effect.
I did put the resistor across the terminals so I could try putting them in series on the centre as per your suggestion terminal and see what happens but should this be necessary?
I suspect folks will need additional info for troubleshooting so please ask away!
Breaker.
