Author Topic: JAMMA to a WG K4600  (Read 1969 times)
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
JAMMA to a WG K4600
« on: July 26, 2008, 10:36:03 pm »
WG K4600 P307 or P317 (according to Menace's faq via Ken Layton).
The JAMMA board I'm using outputs R, G, B, ground, and "Vertical Sync" (no mention of positive or negative), but there are input pins on the yoke daughter card for R, G, B, ground, vert+, horiz+, vert-, and horiz-.
Will I be able to use this monitor with this board?
Ken Layton
  • Guru
  • Technician
Re: JAMMA to a WG K4600
« Reply #1 on: July 26, 2008, 11:25:57 pm »
JAMMA standard sync is composite negative sync. Connect to the -H sync pin on the 4600's video interface board.
MinerAl
  • duck
« Reply #2 on: July 27, 2008, 12:54:31 am »
Thanks Ken!
