Author Topic: Is this possible?  (Read 1754 times)
Plow King
  • Last login:June 28, 2003, 11:57:33 am
Is this possible?
« on: June 07, 2003, 06:13:45 pm »
Hi all , my first post. Great forums btw :)
Could you take a metal control panel (1 or 2 player version) from a astro city type jap cabinet and somehow convert it for use with consoles or pc? I'm after the Sanwa parts (and the base too) you see and I've seen single player panels for
Plow King
Re:Is this possible?
« Reply #1 on: June 07, 2003, 06:24:17 pm »
I'm an idiot, disregard topic guys. Been reading about the I Pac. Sorry :(
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #2 on: June 08, 2003, 03:02:57 pm »
if you have the jamma harness in tact you could use a JPAC to plug right into that... although that's only really useful for PC application, i.e. no love for consoles.
If you *HAD* to have both consoles and PC in the same cabinet you could go the playstation pad hack and usb adapaters / adapters to other systems... or use an x-arcade encoder pcb with the adpaters for your system...
*shrug* good luck and welcome to the boards!
RAmpy
Plow King
« Reply #3 on: June 09, 2003, 07:46:44 am »
Hi Rampy
Thanks for that, very helpful. Thanks for the welcome too :)
rampy
  • *shrug*
« Reply #4 on: June 09, 2003, 11:55:10 am »
I think I misunderstood your original query, upon a second reading...
Are you making a desktop controller (er... lap controller) to interface with your PC/consoles?  If so my advice was off center -> I assumed you were using the whole astro city cabinet, and not just the control panel.
An ipac, or key wiz or mk64, or playstation pad hack or x-arcade pcb with adapters *may* be what you are looking for... depending =P
good luck,
rampy
Plow King
« Reply #5 on: June 09, 2003, 06:35:35 pm »
I would only be using the control panel Rampy :)
