Author Topic: Rowe AMI Jukebox info  (Read 3833 times)
Falkon215
  • Last login:December 31, 2023, 01:39:04 pm
  • Who Ever Swallows The Most Tylenol PM Wins!
« on: July 20, 2008, 10:58:34 pm »
Just looking for some ,wire specs,parts,general info for Rowe AMI 200,model r-85.
I have some sound issues.AMP was bounced around,during the move.It worked in friends basement,but he was using a remote volume control and surrond external speakers.Jukebox has been moved to my father-laws basement.Would like to get the jukebox speakers working.Any common problems I should know about?
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe AMI Jukebox info
« Reply #1 on: September 24, 2008, 11:51:45 am »
Hi Falkon215,
The problem will be more than likely down to dry joints (cold joints in the USA) check out all of the connections going into/out of  the amplifier.
Also look at connections that go between the amplifier preamp and the driver boards.
A dry or cold joint is where a connection or component is solded to the circuit board this usually appears as a crack around the soldered joint.
Regards
Alan Hood
ami-man
UK
Falkon215
« Reply #2 on: October 02, 2008, 10:36:46 pm »
Thanks I went and ran diag on the wire harness for opens and found bad connections to the remote volume control unit.upper speakers are shot sound like crap.going to replace them.hooked up some old realistic speakers around the basement.sounds good.Old Amp is working great. :cheers:
