Author Topic: Speaker Grills  (Read 7424 times)
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
Speaker Grills
« on: June 06, 2003, 04:33:55 pm »
I am always amazed when I CAN'T find something on the Internet.  I am just about done with my cab.  I have a bunch of speakers installed, including 2 small 2 3/4" speakers I hacked out of a PC Speaker setup.  Problem is I can not find a speaker grill that small.  I need a grill between 2.75"-3.25" (preferably 3").  The peice of wood the speaker is on is only 3.25" wide, so I can't put a bigger grill on the speaker.
I can not find a speaker grill this small.  I checked local stores and all over the internet.  I only found one place on the internet that has square ones that at 3 1/8", but they have a minumum order of 15 peices.  I would have thought that car stereo places would have it (like crutchfield.com) since car tweeters are usually that small, but I can't find anything.  I even checked out things like small fan grills (pctoys.com has some cool looking fan covers - shaped like skulls, alien heads, etc that I figured would look cool and do the job - I found them in a local store but their smallest one is too big).
Does anyone have any ideas of a place on the internet that would sell something a small speaker grill?  Or if anyone has another idea?
Thanks for any help you can give!
Doug
:) Rotate or die! :)
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
Re:Speaker Grills
« Reply #1 on: June 06, 2003, 04:40:29 pm »
If you can't find one, you could alway make one.  You can buy that speaker grill material..  I forget what it's called.
Now with cup beer holders!
BobA
  • What Me Worry?
Re:Speaker Grills
« Reply #2 on: June 06, 2003, 04:40:49 pm »
You can cut your own from perf metal with tin snips.  Good way to get covering for irregular shapes or non standard sizes.  Get it at a local supplier or other sources.
One sourcehttp://www.mcnichols.com/products/perforated/pp_main.htm
BobA
CM
  • Last login:January 02, 2012, 08:59:17 pm
  • The internet?!? Is that thing still around?
Re:Speaker Grills
« Reply #3 on: June 06, 2003, 05:43:04 pm »
I was in the same boat as you and ended up saying screw-it ...  the result wasn't too bad actually ... routed the hole and lined it with T-molding:
http://mame.joshuasite.com/images/resized/Sound-Speakers%20-%20finish_html.jpg
Rocky
Re:Speaker Grills
« Reply #4 on: June 07, 2003, 02:27:09 am »
I went to Circuit City and asked if they had any (in the car stereo installation place.)  They gave me a set they had lying around.
Rocky
REBIRTH
  • What is that?
Re:Speaker Grills
« Reply #5 on: June 08, 2003, 10:05:03 am »
Good idea, but I have the actual speakers, flush mounted on the wood - and 3 little kids running around who would love to stick their filthy little fingers right through them!  :P  I need some covers.  I went to Circuit City too, no dice.
Sprucemoose
  • Last login:March 23, 2009, 03:56:10 pm
  • You Spent How Much?!
Re:Speaker Grills
« Reply #6 on: June 09, 2003, 10:58:57 am »
I actaully used black sewer grates from Home depot.  $2 a piece.  They work great and are easy to install.  Will get a picture up soon.
aumameman
  • Last login:November 18, 2009, 09:50:07 pm
  • AUSSIE MAMER !!
    • Arcade joystick - First attempt
Re:Speaker Grills
« Reply #7 on: June 09, 2003, 11:06:40 am »
Why not visit your local car radio store and buy a couple of car speaker grills??
Maybe Radio Shack have something that would do the job??
-- The Internet has you --
Les
  • Last login:April 07, 2012, 12:05:55 pm
  • "You had me at show your tits."
    • Arcade Legends
Re:Speaker Grills
« Reply #8 on: June 09, 2003, 11:56:00 am »
REBIRTH
  • What is that?
Re:Speaker Grills
« Reply #9 on: June 09, 2003, 01:10:36 pm »
4" speaker grilles can be order through HAPP controls:
http://www.happcontrols.com/amusement/jukebox/49518100.htm
or square:
http://www.happcontrols.com/amusement/jukebox/49518200.htm
Thanks, but 4" is too big, can't be bigger than 3.25".
And to answer Les, I went to 3 car stereo installers and non of them had anything smaller than 5".  Radio shack as well, smallest they had were 5".
Thanks for the help and ideas everyone.
Birdtales
  • Last login:October 06, 2020, 10:00:31 am
  • You won't like me when I'm angry.
    • Birdtales
Re:Speaker Grills
« Reply #10 on: June 09, 2003, 01:16:12 pm »
How about a muffin fan grill. I've used them to cover speakers on a computer case mod before. Note on this grill the mounting holes are 3.25" apart. Should keep out the fingers.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2535925558&category=36324
Coming Soon
AlanS17
    • AlanS17
Re:Speaker Grills
« Reply #11 on: June 09, 2003, 01:20:50 pm »
Don't rig it. Do it the right way. Radio Shack sells speaker grills. So do car audio shops. I got the speaker grill for my cabinet from Radio Shack.
REBIRTH
  • What is that?
Re:Speaker Grills
« Reply #12 on: June 09, 2003, 01:27:12 pm »
As I said, Radio shack doesn't sell anything smaller than 5" (at least my 2 local Shack's and their website).  Same with the car audio dealers near me.
CM
Re:Speaker Grills
« Reply #13 on: June 09, 2003, 02:48:03 pm »
There is a defined RIGHT way to do things now?  ???   (must have missed that thread)  ;)
Anathematizer
  • Last login:September 05, 2023, 05:24:07 pm
  • I find your lack of faith... disturbing.
Re:Speaker Grilles
« Reply #14 on: June 09, 2003, 04:18:12 pm »
You could go to your local Bose dealer and try to find a replacement grille for one of the cube speakers.  E.g., the acoustimass/jewel cube speaker has a removable grille that is @3.1"x3.1". You should be able to get one that does not have a Bose tag on it - the acoustimass/jewel cube panel array has two cube speakers, the bottom one with the Bose tag on the grille and the top one without.
Or you could always buy a roll of grille cloth (fairly inexpensive) and buy a foam block (from Michaels, etc...)  from which to punch/cut-out a rectangular frame from and roll your own...
If you do a search for "speaker grilles" (usually spelled with an e I think ;D) you can find circular grilles that size and a little smaller.  The rectangular grilles usually are not smaller than 3.5"x3.5".
Good luck.
« Last Edit: June 09, 2003, 04:42:20 pm by Anathematizer »
Expecting the world to treat you fairly because you are a good person is a little like expecting the bull not to attack you because you are a vegetarian.
- Dennis Wholey
