Author Topic: 15, 25, 31khz monitor?  (Read 1662 times)
Ummon
  • Trade Count: (+13)
« on: July 18, 2008, 03:42:03 pm »
I remember some here saying there's a switch of some kind, or jumper?, on some monitors that change the scan rate accepted. Not the best image, but what should I be looking for here?
Yo. Chocolate.
Stephen Hawking
grantspain
  • Last login:Yesterday at 04:58:13 pm
Re: 15, 25, 31khz monitor?
« Reply #1 on: July 18, 2008, 04:13:04 pm »
3 ways multi sync switch
jumper plug on the main chassis,you will find two connections marked low/high-this will be 15/25 only
on the control board there will be 2 switches which produce different options like on the early nanao tri sync
most tri sync will auto range to the correct signal,some have a signal impedence switch on the control board such as the rodotron and wei ya
some dual sync 15/25 are auto sync as well
normally a tri sync will have a vga connector as well as a 5/6 pin rgb connector
Ummon
« Reply #2 on: July 22, 2008, 09:34:49 pm »
I didn't see any of those things you mentioned. However, after some testing, I found it is an autosync, apparently 15/25.
Yo. Chocolate.
Stephen Hawking
