Author Topic: Question about using 12V line in computer to power LEDs  (Read 957 times)
Jdurg
« on: July 18, 2008, 11:46:11 am »
One small question here.  I've got my LED sockets for my Coin Door LEDs and my Trackball LED wired up to a two pin Molex Connector.  I plan on taking a couple of the 12V 4-pin Molex connectors from the Computer Power Supply and adapting them to work with the Two Pin Molex connectors on my LEDs.  What do I do with the +5V line and the other Ground line?  Do I just cut those lines from the base of the connector and wrap the ends in electrical tape to ensure they don't touch, or do I need to connect them to each other somehow to complete that circuit?
My brain is saying 'Just snip them and make sure the exposed metal doesn't touch anything by epoxying over the ends'.  I think my brain is right, but I want to verify that.   :cheers:
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Re: Question about using 12V line in computer to power LEDs
« Reply #1 on: July 18, 2008, 01:48:20 pm »
your brain is correct.  you don't need 'em at all.  I have 6 lights connected this way in my cab, plus an amp for the audio, all using only the 12v lines.  I did need a ground loop isolator for the amp, but that's a topic for a different discussion.
-jeff!
Teknique
  • Last login:October 02, 2015, 10:35:46 am
  • I'm a Gauntlet wizard in real life
« Reply #2 on: July 18, 2008, 01:48:36 pm »
snipped mine and taped them with no problems.
tek
Your screen name has been added to my frag list.
