Author Topic: Maximus Arcade question. 640X480 hurts my eyes, need to run at 640X240, HOW?  (Read 4130 times)
vetteguy112233
  • Last login:April 28, 2012, 12:15:24 am
Whenever I run my cabinet (P4 2.9GHz, Win XP, 1GB ram, ArcadeVGA) at 640X480 it has a certain flicker that eventually gives me a splitting headache (windows xp and games), if I change it to 640X240, it looks good and doesn't give me a headache.
I've recently switched to Maximus Arcade and it's default setting is 640X480, which I just can't take the headache anymore, does anyone have any suggestions?
jardine
  • Last login:May 12, 2025, 05:09:12 am
go back to MameWah...!!??
vetteguy112233
But Maximus is perfect other than this one issue. Even in Mamewah at 640X480 it does the same thing, so it's not necessarily the Front End, it's my cabinet. I was just hoping that there might be something someone knows of.
Ginsu Victim
  • Last login:June 28, 2025, 10:45:55 pm
  • Comanche, OK -- USA
With Mamewah's layout editor, you can set the resolution to pretty much whatever you want.
youki
  • Last login:November 19, 2016, 01:07:33 pm
  • Atomic Front End Creator
    • Atomic Front End
All front end in 640x480 on a 15khz arcade monitor will flicker.
If you have a ArcadeVGA or you use Soft 15hz.  you can manage to use resolution of 640x288 (or less) . In that case it won't flicker.
Mamewah , mala  and AtomicFe at least can work in 640x288 .
If Maximus can not ,  the only choices you have are :
Do a skin with dark color (not White!!!) to see less flickering.
Or change your monitor to have a 31khz one.
Or Change your front end.
On a 15khz monitor or TV , all vertical resolution above  288 point will flicker anyway.  Because your screen can not display more line. If you force to display more, it will be interlaced and will flicker.
  • Last login:July 11, 2025, 09:17:44 am
The new version of Maximus Arcade (2.10 beta 6) was released yesterday which corrects this problem!   :applaud:
- *Finally* fixed batch launching problems (correct syntax is mandatory within batch file)
- Fixed miscellaneous timing issues
- Fixed script errors occurring when exiting the frontend
- Fixed CPS3 and Sega Model 2 launching problems (executable is now minimized instead of hidden upon launching)
- Fixed problem where keystroke delay options weren't saved
- Fixed WinKawaks launch/exit problems
- Fixed potential command line variable based problem
- Added yellow marquee and desktop wallpapers under freebies
- Added support for FinalBurn Alpha (0.2.96.77) emulator
- Added 640x288 and 640x288 vertical support
- Added support for nulldc_100b1_6 (Sega Dreamcast)
- Be sure to use nulldc_100b1_6 instead of nulldc_100b1
- If XVID drivers detected, compatible settings are forced
- Version number now appears in preferences next to registration info
- MAME is now closed politely upon exit (again)
- Updated the Skin Editor 1.5 to Theme Editor 1.6
- Added support for FinalBurn Alpha to Theme Editor
You can grab it here:
http://www.maximusarcade.com/phpBB2/viewtopic.php?t=1331
~ DeLuSioNaL
RoomTenONine
  • Last login:August 20, 2008, 07:00:38 pm
Nice.  This is a great set of updates to MA.  Nice to see this monitor resolution support added.  For me though, the nest is it fixes the WinKawaks exit routine!  Hell yes.
