Author Topic: Quick Question About Button Wiring??  (Read 2039 times)
lettuce
  • Make It So!
« on: July 13, 2008, 04:45:05 pm »
Ok im going for a 7 button setup for my new cab lets say for example:
1234
567
Now can i wire the buttons so instead of actually have 7 individual buttons i have 2 buttons wired up together and they wont conflict with each other, ie
1234
456
I'll be using the wiring harness that you get for the U360 sticks not an I-PAC board!
boogieman
  • Last login:January 19, 2019, 05:35:48 pm
  • advancedspuds.com
    • advancedspuds - your source for spudgun information
lettuce
  • Make It So!
Re: Quick Question About Button Wiring??
« Reply #2 on: July 13, 2008, 06:25:07 pm »
Cheers
lettuce
  • Make It So!
« Reply #3 on: July 22, 2008, 11:42:30 am »
Ok im not 100% sure how to best go about this when using the U360 stick wire harness, is it ok to dasiy chain the 2 buttons i both want as 4 to one another, ie
« Last Edit: July 22, 2008, 11:54:31 am by lettuce »
VonnerNIX
  • Last login:January 08, 2012, 01:46:14 pm
« Reply #4 on: July 22, 2008, 04:40:57 pm »
I can think of no reason where that would be an issue.
It is essentially the same thing you are doing with the ground wires.
Mamushka
  • Last login:August 01, 2008, 10:44:03 am
« Reply #5 on: July 23, 2008, 07:28:03 pm »
Your drawing is not quite right. You want the red wire tied directly to the black wire entering the first "4" button. The way you have it drawn it looks like it is series, you need it in parallel.
John
Jdurg
« Reply #6 on: July 24, 2008, 10:16:06 am »
John
That's exactly what he has there.  It's daisy chained together so the two wires merge at the button.  That's the proper way to wire it.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
