Author Topic: Centipede board help  (Read 2302 times)
Hawkypro
  • Last login:October 13, 2009, 10:00:27 pm
« on: July 10, 2008, 09:55:11 pm »
Guys,
Ive got a centipede board that has a humming sound coming from the board. Ive done the ARII upgrade and replaced the big blue cap ect... and replaced the pokey chip. I know its coming from the board because I connected a speaker to the speaker output on the edge connector and still get the hum. I can hear the game sounds if I listen closely. If you guys have any suggestions let me know.
Thanks,
Hawkypro
As you can see Dr. Jones there is nothing you can posses; which i can not take away.
Level42
Re: Centipede board help
« Reply #1 on: July 11, 2008, 08:46:24 am »
Replace the LM324. It often dies. It did on my board too. Replaced it and works great.
Hawkypro
« Reply #2 on: July 11, 2008, 07:38:51 pm »
Level42,
Thanks for the info, and I hope my machine looks like yours when im done restoring it. I will look at LM324 and let you know what I get. This problem has had me stumped for a while.
Update: Replaced LM324 and still have the problem,  :banghead:
Hawkypro
« Last Edit: July 11, 2008, 07:58:29 pm by Hawkypro »
Level42
« Reply #3 on: July 13, 2008, 09:21:21 am »
Well that's mostly all you can do on the game-board. You mention you did the AR=II upgrade. Did you just do the cap-kit or more ? The TDA on the AR-II is the next step where the audio gets amplified so that could be gone too.
tafische
  • Last login:July 22, 2008, 10:54:49 pm
« Reply #4 on: July 16, 2008, 12:22:23 am »
Have you checked the volume control knob?  I have a new Centipede machine and I have to "work" the knob a little bit or I get some hum.
[ Centipede // Zaxxon // Vanguard // Cocktail Defender // Mame - Homebuilt Galaga Replica ]
Hawkypro
« Reply #5 on: July 17, 2008, 12:20:21 am »
Level42,
Yes, Ive done more than just the caps on the AR=II  :dunno so im still troubleshooting the problem.
Tafische,
Yeah, ive done that with volume knob.
thanks for the input so far from the both of you guys.
Hawkypro
