Author Topic: t-molding on the control panel  (Read 1215 times)
TAG
  • Last login:May 23, 2014, 05:52:05 pm
« on: July 10, 2008, 01:00:48 pm »
For those of you with control panels that extend beyond the outer edges of the cabinet, and for those who've put t-molding along the edge of the top of the control panel...do you have the t-molding going all the way around, or do you not bother with putting it on the back of the panel top?  Thanks!
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
-- Dirk Gently
Doctor Ugs
  • Last login:May 14, 2011, 02:56:58 pm
  • Arcade addict since 1980
Re: t-molding on the control panel
« Reply #1 on: July 10, 2008, 03:50:11 pm »
i put mine all around.
"My memory is so bad,
Alzheimer's would be an improvement!"
My Project Thread, 2 Mame Cabs.
Zeno
  • Last login:May 12, 2009, 11:22:33 pm
  • Movement is an illusion
« Reply #2 on: July 25, 2008, 03:16:07 pm »
I think it is totally dependent on the individual CP.
I have a metal flush plate that is on the back of mine.  The T-molding only covers about 1/3 of the back.
Generally, I would say to wrap it as much as you can.
Zeno
Running: MAME
Projects: MK3, Ms. Pacman
