Author Topic: kortek 2914f dim  (Read 2722 times)
fargen
  • Last login:July 09, 2017, 01:11:56 pm
kortek 2914f dim
« on: July 05, 2008, 05:31:06 pm »
heya, I have a 2914f in a target terror and its going dim. The tube tests ok but I heard the flybacks were not great with this model. Does anyone know anything about cap functions on this board to try first to improve pic? or any other ideas? thanx sbm
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: kortek 2914f dim
« Reply #1 on: July 12, 2008, 10:13:31 pm »
generally, an IHVT (flyback)  either works or it doesn't.
not much of a grey area there ......
is the OSD nice and bright , and just the game vid dim ?
service manual here :
www.retroblast.com/files/KT-XX14X-SM.pdf
qrz
MonMotha
« Reply #2 on: July 13, 2008, 05:48:01 am »
Flybacks haven't given me any problems, and I know of several cabinets with this, the DF (completely flat) variant, or the 34" DF model.  There is side squishing, but that isn't likely related.
I have known the ACL to be problematic, however.  It may be engaging too soon, especially on smallish signals.  You can go into service mode (hold up button as you power the device) and adjust the ACL control upwards.  Be aware that this may also compromise the ability to prevent phosphor damage if you feed it a huge signal with contrast cranked, so don't go nuts.  Be sure to note all original service mode settings, as always, because there's no way to "restore" them.
fargen
« Reply #3 on: August 02, 2008, 10:35:04 am »
heya, just for update...I capped this monitor with a cap kit I got from zanen. Picture came back just like new. The zanen kit was short two or three large caps and also noticed one chassis had one cap running in one direction and the other was running as stated on the board. So please pay attention on this chassis. I will post later the caps missing and the cap that was backwards in one.
neokidgeo
  • Last login:June 16, 2019, 03:12:39 pm
  • Uncle rico sends his love
« Reply #4 on: August 03, 2008, 11:59:18 am »
Nice to hear you got your monitor working  :) i have a kortek myself that has the same problem, What caps are included in the kit and ones that are missing? i ordered a kit a few weeks ago but the caps were completely different  :'( sorry if i'm high jacking  :-[
UkVacer
fargen
« Reply #5 on: August 11, 2008, 09:28:43 pm »
email me at natas1504@aol.com and I will send you the cap list....sbm
