Author Topic: 9v DC to 3v DC and 1 9v DC to 2 9v's and 1 3v need some help ???  (Read 1341 times)
david656
  • Last login:June 01, 2017, 10:06:24 am
  • Big Man!
im doing a little project and need to step down 9v DC from the wall to 3v DC... what would i use to create this effect ?
and how do i wire 2 seperate 9DC things to the same DC plug/transformer? do you do it in series or parallel or ?
any insight would be great !
thanks
Ed_McCarron
Re: 9v DC to 3v DC and 1 9v DC to 2 9v's and 1 3v need some help ???
« Reply #1 on: July 01, 2008, 09:06:26 pm »
2 separate devices to one power supply?  Parallel.  Just be sure that the current rating on the PS will handle both devices.
9 to 3v?  http://www.dimensionengineering.com/DE-SW033.htm is a hybrid switching reg - in a 78XX footprint.  It'll handle up to 1A at 3.3v.
Franco B
« Reply #2 on: July 02, 2008, 01:17:26 am »
I take it you are using a 9v DC 'plug' PSU? Why not just get a 3v one? [Here's one] from Maplins for £6.
david656
  • Big Man!
« Reply #3 on: July 03, 2008, 05:29:14 pm »
if i got another lead/ transformer it would just be taking up more room in a confined area :-( and therefore not reallly a option ! if worst comes to the worst im gunna have to use batteries which will run down in no time :-(
can i not use a load of resistors or summit !?
grantspain
« Reply #4 on: July 03, 2008, 05:33:00 pm »
what the bloody hell are you up to??
david656
  • Big Man!
« Reply #5 on: July 03, 2008, 05:46:54 pm »
ha ha ! its not what you think !  :timebomb:
my amstrad cpc464 died and i have took it apart and re wired the tape drive to play stereo audio tapes and am planning on shuvving a windows PC maybe nano ITX or pico ITX in there BUT to get the tape drive to work with out the amstrad boards i hacked a walkman into it ! but obviously the batteries would die quick so need to DC mains power it ! and the tape motor seems to be 9v as is the other amp ! but the walkmans 3v  ???  :(
Ed_McCarron
« Reply #6 on: July 04, 2008, 05:33:57 pm »
Sure, as long as the current drawn never changes, and you don't mind things getting hot enough to melt plastic...
