Author Topic: What front end will work best for my setup?  (Read 1962 times)
vetteguy112233
  • Last login:April 28, 2012, 12:15:24 am
« on: July 01, 2008, 03:06:42 pm »
I've got a P4 1.7 with 512MB Ram (for now). Running ArcadeVGA and IPAC 4. Currently have 5 buttons for each of the 2 players (will eventually have 6 each).
I want a layout similar to MameWAH, but not as complicated. I want to be able to switch between different emulators (atari, nes, snes, sega, gameboy....), see a picture of the system being emulated and stuff like that. I eventually want to replace the buttons with the LED lightup's, so the buttons that work for that game will glow.
MameWAH just takes too long to setup, editing all the .ini files, is there anything easier/better?
I'm willing to sit down and edit all the .ini's for mamewah if I have to.
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Re: What front end will work best for my setup?
« Reply #1 on: July 01, 2008, 03:58:21 pm »
how about mala?
handles multiple emulators, the plug-ins could do your led's and with the right layout, you can get a system of the emulated console + the listing of roms to play on it.  Super easy to set up and works great with an arcadeVGA.
-jeff!
massive88
« Reply #2 on: July 01, 2008, 04:02:48 pm »
Mala is very similar to Mamewah, only less versatile and easier to configure.  Its definitely worth downloading and checking out to see if it fits your needs.
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #3 on: July 01, 2008, 04:33:19 pm »
AtomicFE  ;)
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
« Reply #4 on: July 01, 2008, 08:09:11 pm »
Gotta chime in with the vote for Maximus Arcade.  The ease of use in setting it up is easier than any of the ones mentioned.  No ini's to edit, no possibility of accidentally accessing configs, easy enough for a 2 year old to use.
HyperSpin will also be easy to use with very very minimial setup.  Unfortunately we are still a way from that point right now, but it is coming.
boogieman
  • Last login:January 19, 2019, 05:35:48 pm
  • advancedspuds.com
    • advancedspuds - your source for spudgun information
« Reply #5 on: July 02, 2008, 02:29:40 pm »
I like maximus arcade also.  It is real easy to configure and already has great pictures of the different gaming systems/consoles.
9innail
  • Last login:September 22, 2011, 11:18:53 am
« Reply #6 on: July 02, 2008, 07:13:53 pm »
I would say Maximus Arcade also. Its the only front end I've ever used and I've never felt an urge  to try any other.It fulfills all my needs.
jardine
  • Last login:May 12, 2025, 05:09:12 am
« Reply #7 on: July 03, 2008, 02:14:16 am »
I will add my vote to mamewah. Being new to it at the time it did seem confusing, but once you get your head around it a great frontend.
Not only that but Minwah is always roaming these threads to give advice if needed.
My thumbs up to Minwah and Mamewah for sure.
vetteguy112233
« Reply #8 on: July 06, 2008, 05:23:04 pm »
I've checke out all of the suggestions and I guess I'll stick with Mamewah. I gave MALA a very lengthy try, but it's just not what I want.
I'm just so frustrated with Mamewah because I can't get my Atari2600 to work. I've checked/double checked/tripple checked the .ini file and it still doesn't show it in my list when I access the menu. I'll keep messing with it, I'm sure once I figure out this problem, the rest will be easy.
Thanks again for the suggestions.
