Author Topic: FS: Supergun w/ 2 Controllers $245  (Read 2332 times)
Red
  • Last login:November 07, 2017, 08:37:51 am
« on: June 28, 2008, 07:40:22 am »
I'm selling my Custom Built Supergun unit complete with the Supergun unit itself, two 6-Button Controllers, CPS2 Speaker, AC Power Cable, S-Video Cable for $245.  You pay for whatever shipping you want from NY, 12866.
I also have Atari's Relief Pitcher Baseball PCB for sale for $15.
For those that don't know about Superguns, they allow you to play Arcade games (PCB's) on your home TV. Most JAMMA PCB's are Plug 'N Play. Simply plug the game PCB into the JAMMA harness and hook up the video cable to your TV (It comes with an S-Video cable, but you can also use a Composite cable if you want) and turn on the power switch and now you're playing all those arcade games you love right in the comfort of your own home!
About the Supergun- I'm using the CV-04 video chip inside. Better than any of the video chips inside a produced Supergun, such as the MAS Supernova. The CV-04 has high compatibility and crisp composite and s-video. It uses a standard s-video or composite cable and is color adjustable and also outputs in NTSC/PAL.
The controllers and system use the same plastic trim as an arcade and the controllers have a thick protective plexi glass cover just like in the arcade
It has a high quality ATX power supply with an easily accesible and reliable power switch on the back. It also has inline fuse holders. The power supply is already wired to accept all board voltages.
It has Test and Service buttons on main system with Coin and Player Start on the controllers and Button 4 is hooked up like a Neo.
Comes with an actual CPS2 speaker from the big blue cabinets for sound (Pictured on left of Supergun 2 picture).
It also has a decent and sturdy JAMMA harness with a tight fit. Again, better than the other produced Superguns and has a CPS2/3 kick harness for buttons 4-6.
This Custom Built Supergun system isn't perfect, but works great. It is hand made and has some imperfections. For example, the top doesnt fit perfectly, but that's good though because you can put wires out of it and it also makes the inside components easily accessible.
Here are some pictures:
http://farm4.static.flickr.com/3265/2589002315_ae871d39f0_o.jpg
http://farm4.static.flickr.com/3191/2589002351_4bfd9d1e21_o.jpg
If you have any questions, don't hesitate to ask. Thanks.
« Last Edit: August 03, 2008, 01:20:06 am by Red »
Red
Re: FS: Supergun w/ 2 Controllers *Play Arcade Games on your TV!
« Reply #1 on: July 04, 2008, 04:19:14 am »
Bump.
Red
« Reply #2 on: July 12, 2008, 04:55:07 pm »
Bump.  I will also entertain all trade offers.  Thanks.
Red
« Reply #3 on: July 27, 2008, 09:32:42 pm »
Price lowered.
Red
Re: FS: Supergun w/ 2 Controllers $245
« Reply #4 on: August 03, 2008, 01:20:36 am »
Bump.
Red
« Reply #5 on: August 13, 2008, 11:51:38 pm »
To the top!
