Author Topic: J-stik mounting???  (Read 1404 times)
RoomTenONine
  • Last login:August 20, 2008, 07:00:38 pm
J-stik mounting???
« on: June 27, 2008, 12:08:23 pm »
I'm planning on using two 8-way Ultimarc J-stiks with oval/bat tops on my new build.  I have read that they are a bit short and I may need to route a recessed area under the CP so they stick out far enough.  Is this true?  Can I just mount straight on the bottom with a 3/4" thick board or do I need to use a router?  If I must route how thick should the recessed area be?
This will be for an all-purpose MAME cabinet with an emphasis on fighters and shooters, so I wanted a nice tight and precise joystick.  Thought about going for a Happ competition, but it sounds as if everyone prefers the j-sticks for fighters/shooters.
TIA  :)
Ginsu Victim
  • Last login:June 08, 2026, 03:12:14 pm
  • Comanche, OK -- USA
Re: J-stik mounting???
« Reply #1 on: June 27, 2008, 12:19:35 pm »
Just get the longer shaft. I'm using balltop U360s with the standard shaft mounted under 3/4" (5/8" wood, 1/8" plexi) and they're fine to me, but some people might want longer.
RoomTenONine
« Reply #2 on: June 27, 2008, 07:25:12 pm »
I thought the longer shafts were only available for the ball top J-stiks and U360s, not the bat style J-stik.  Am I wrong?  I can't find anything to say otherwise on Ultimarc's website.
I dunno now.  I may end up going with the "old" Happs Comps made by iL (who oddly enough makes the T-stik for Ultimarc).
Anyone else have thoughts?  Anyone route the bottom out for a J-stik?
Ginsu Victim
« Reply #3 on: June 27, 2008, 07:34:59 pm »
No, I'm wrong. I assumed they had the longer shafts for those as well.
RoomTenONine
« Reply #4 on: June 27, 2008, 07:38:50 pm »
Maybe I'll just get ball tops.  Agggh, too many decisions! :banghead:
Ginsu Victim
« Reply #5 on: June 27, 2008, 08:34:48 pm »
Maybe you could get the extra long balltop shaft, then replace the ball with bat using the adapter sold here.
http://www.lizardlickamusements.com/pages/joysticks.shtml
Another thing where I know it works for the U360, but not sure about the J-stik.
