July 04, 2026, 01:10:00 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Video Games
through our link. Thank you!
Main
Main Forum
Sanwa/Seimitsu Push Buttons?
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Sanwa/Seimitsu Push Buttons? (Read 5248 times)
lettuce
Trade Count:
0
Full Member
Offline
Last login:December 31, 2021, 01:46:10 pm
Make It So!
on:
June 27, 2008, 08:35:20 am »
Are any Sanwa/Seimitsu push buttons designed for (or have a shaft long enough) to work with a wooden CP, as i notice alot of them are designed fot a metal CP and just clip in place rather than screw with a plastic nut?
Logged
Turnarcades
Trade Count:
0
Full Member
Offline
Last login:May 13, 2017, 08:14:29 am
Craig @ Turnarcades
Re: Sanwa/Seimitsu Push Buttons?
Reply #1 on:
June 27, 2008, 08:49:09 am »
Not sure, but if not, either route out the section underneath where your buttons are or use some kind of bonding agent and just jam them in the holes!
Logged
Kajoq
Trade Count:
+2
Full Member
Offline
Last login:June 14, 2024, 11:28:46 pm
Reply #2 on:
June 27, 2008, 09:56:44 am »
There are screw in sanwa/seimitsu buttons. They dont have nearly the same thread length as happ, so if you're using thick MDF you might still have to route the underside some. If you have a plexi top on your CP though, the buttons will clip right in to the plexi. That is how my CP is set up.
Go to
http://www.lizardlick.com
if you're looking for Sanwa stuff
Logged
Kaytrim
I'm too nice a guy
Trade Count:
+4
Full Member
Offline
Last login:September 22, 2015, 04:11:30 pm
Reply #3 on:
June 27, 2008, 12:12:57 pm »
Even though the Sanwa/Seimitsu buttons have nuts they are still rather short. I use 1/2" MDF and 1/8" plexi and still have to drill out space for them. I use a 1/8" drill bit for a pilot hole. Then use a 30mm forsner bit on the top and a 1 1/2" forsner bit on the bottom. I only drill halfway through with the forstner bits and meet in the middle. You could also use two 1/4" MDF boards in a sandwich, one has the holes for the buttons and the other has a larger hole so you can screw on the nuts.
Here is a pic of my 1/2" MDF board. It is a little hard to see but you can see the recesses for the buttons on the left side.
Logged
Dad's Centipede Bartop
http://forum.arcadecontrols.com/index.php/topic,66082.0.html
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
