Author Topic: Slot Cutting After Construction?  (Read 3028 times)
jeffhlewis
  • Last login:July 28, 2026, 12:52:36 am
    • Lewisjeff.com
« on: June 26, 2008, 12:59:10 am »
I've got a time dilemma on my hands here....I ordered a 1/16th slot cutter from Amazon (couldn't find one anywhere here strangely between Menards, Home Depot, Lowes, and True Value) and the ---daisies--- aren't going to ship it until like the last day in June - with an expected arrival between July 1st and 7th (ugh).  I'm moving in about a month so every weekend I get I have to be out in the garage finishing this project up.  My two sides have been cut even with a router and I've been working on getting tack strips cut for my initial mounting.
My question is - can I just run the slot cutter over the sides once the cabinet is assembled (but unpainted)?  I figure it might be a bit more cumbersome than doing it prior to assembly but I don't have time to idle around for another week.
thanks!
Blanka
Re: Slot Cutting After Construction?
« Reply #1 on: June 26, 2008, 01:10:00 am »
If you can run of the edge with it: yes, if a part that needs T-bolding is locked between two other panels, than: no. Just go along the edges with the router to imagine what will work when you get to the T-molding point.
Franco B
« Reply #2 on: June 26, 2008, 03:41:41 am »
Just make sure there will be no screws/nails etc in the cutter path, you dont want the cutter hitting one of those at ~20,000RPM.
jeffhlewis
    • Lewisjeff.com
« Reply #3 on: June 26, 2008, 09:37:55 am »
That's pretty much what I thought but I figured I'd consult the experts first.  What I should actually probably do during my downtime is get my blog site finished so I can post a worklog, haha.  Or better yet actually announce the project on this forum.
I don't have any interior T-Molding (my control panel is recessed) so it should be a problem - just the two sides.
Chadwick
  • Last login:January 11, 2010, 03:23:34 pm
« Reply #4 on: June 28, 2008, 05:33:43 pm »
This is paramount!  An off-the-shelf 1-78" slot cutter will have a 1/2" depth of cut.  Wear those saftey glasses!
jeffhlewis
    • Lewisjeff.com
« Reply #5 on: July 04, 2008, 01:54:36 pm »
slot cutting is complete...I got it sooner than expected and got everything taken care of before assembly.  thanks though, guys!
