Author Topic: MAME - Access Violating when disabling HWSTRETCH?  (Read 1096 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
« on: June 20, 2008, 09:22:59 am »
I'm trying to achieve the best possible output on my television but I'm getting an access violating when I disable hwstretch.  I've tried using DirectDraw and Direct3D (along with nohwstretch) but I keep getting an access violation.  When I enable hwstretch then it works fine.
I'm using the latest version of MAME and a fresh install of Windows XP SP2 all patched but without .NET installed.
Here is the exact message I'm receiving:
Exception at EIP=009413BF: ACCESS VIOLATION
While attempting to read memory at 00000028
EAX=00000000 EBX=0022FC28 ECX=00000001 EDX=0022FC28
ESI=00000000 EDI=00000000 EBP=0022F778 ESP=0022F760
Re: MAME - Access Violating when disabling HWSTRETCH?
« Reply #1 on: June 20, 2008, 12:24:20 pm »
I've had this a few times with v0.125u6...DirectDraw enabled.
Strangely I had the error, and then run the same commandline again, and it worked OK. Had this happen a day or two ago, but I can't say I spent any time trying to figure out why  ???
