Author Topic: Lightweight control panel  (Read 1436 times)
Smittydc
  • Last login:October 05, 2008, 12:48:10 am
  • because its fun!
« on: June 03, 2003, 04:15:13 pm »
I want to build a small control panel into a 2-rack slant mount space on my dj-rack, and I think 1/2 or 3/4" wood is a little heavy and too deep.  Any ideas on something else to use?
Thicker lexan?
Lexan with a wooden "frame" underneath?
A metal CP?  Anybody had luck with this? Drilling/cutting metal has always been a pain in the ass.... maybe metal with a lexan cover to disguise ugly holes?
for the record, a rack space is only 19" wide.
Build a man a fire, he's warm for a night.  Set a man on fire, he's warm the rest of his life.
shmokes
  • Don't tread on me.
    • Jake Moses
Re:Lightweight control panel
« Reply #1 on: June 03, 2003, 05:30:51 pm »
And the usable space (inside the rails) is more like 17".  Hope you're building a one-player stick.  I would think that unless you have the tools to do metal or know someone who does you should go with 1/2" plywood.  The Lexan idea is intriguing, though.  If it's strong enough it would sure look cool.
Best Kid iPad Apps
2slk
  • Last login:February 27, 2004, 11:38:09 pm
  • Fascinating, Captain.
« Reply #2 on: June 03, 2003, 05:38:38 pm »
 I think lexan would definitely be strong enough. I know one guy who has his trackball mounted directly on lexan. It gets a lot of abuse and has held up quite well.
 Metal could be a good option as well. If you get the right tools and take your time, it shouldn't be that bad of an experience. A good tool rental service would be able to fix you up for sure.
