Author Topic: help! Need tutorial to get 288 line games to display right on horiz cga monitor  (Read 3966 times)
m_mcgover
  • Last login:July 18, 2025, 12:30:24 pm
Sorry in advance if this has been answered before, but I have not been able to find it all together.
Can someone step me through the mala/mame/ini changes I need to make to make 288 line and greater vertical games playable without loss of lines or squishing at screen top/bottom on my horizontally mounted CGA monitor?
My machine has a 25" wells-gardner k7000 series cga-resolution monitor.  I am using the newer Arcadevga card to drive it.  Mala is my frontend.
I know there are a number of steps, which include fiddling with vertical size and generating .ini files for every game, but I can't seem to find the right combination.  The best I am able to do is get a vertical game like pengo have the bottom really squashed.  Curiously, the top of the screen seems to be undistorted and completely on screen.  I cannot reduce the vsize any more (already at its limit), so what can I do?  Is there a magic combination of settings in the game.ini file that will remedy this?  Is there someother monitor knob I can adjust besides vsize and vpos?
Please someone provide a detailed step by step.  Thanks in advance!
Sinistar, 25" Smash TV, Major Havoc 720, Star Wars cockpit w/ESB kit, Robotron cocktail, Warlords cocktail, Back to the Future pinball
It sounds to me like you have adjusted the vertical size down so much it is distorting the image...perhaps an issue with this type of monitor(?)
m_mcgover
I'll try and re-adjust size back up to see if that helps.  I'm just confused since other appear to be able to get this to work...
Ken Layton
  • Guru
  • Technician
And the monitor is freshly capped? If so, the also adjust the 50/60 control as shown here:
http://jstookey.com/arcade/WG_25k7191/
m_mcgover
Ken-  Thanks for the reply (and the link).  No, the monitor is not freshly capped.  I assume I can still try adjusting the 50/60 to see if that improves things?  I'll give it a shot tonight.  Thanks!
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
I think you need this page:
http://ultimarc.com/avgainst.html
which shows you all the various mame.ini steps to tweak, and has a link to the arcadevga resolution tool to generate the .ini files for each game.  Worked great for me!  I was able to get a few games that had previously come up only as a garbled screen to show properly.
-jeff!
m_mcgover
Yes, I ran Gavin's utility to generate .ini files for each game, prior to my original question.  I guess I can go back and double check that the resolutions suggested by the utility line up with the vertical games and report back.
m_mcgover
Ken was right.  I needed to adjust the 50/60 pot on the monitor to correct what turned out to be mild vertical fold over on the bottom which prevented me from getting the vertical games to display correctly.  I am now able to get pretty close with just the slightest bit of cut-off.  Thanks again to all (and especially Ken) for your suggestions!
