Author Topic: vsyncmame .61  (Read 1969 times)
tikbalang
  • Last login:May 07, 2013, 05:04:54 pm
    • MAME BootCD's for DOS
vsyncmame .61
« on: June 02, 2008, 11:44:42 am »
i need the documentation files for vsyncmame .61 dos. how do i get
into the "tab" menu? there is a "`" menu for volume. how do i reconfig
the buttons? thanks.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: vsyncmame .61
« Reply #1 on: June 02, 2008, 02:00:19 pm »
IIRC, the cfg input files were still binary files back then, so if tab isn't working, you either have to delete the default cfg file, or test every button until you find it (and hope it wasn't remapped to "none").
Otherwise, it was basically the same as now:
  Press the "Config Menu" (aka "UI Configure") button, whose default is the 'tab' key
which is (and was) usually shorted to "press the tab key". ;)
Robin
Knowledge is Power
tikbalang
Re: vsyncmame .61
« Reply #2 on: June 03, 2008, 10:59:45 am »
it's fixed. i don't know what fixed it though. i deleted default.cfg but at the same time i upgraded to vsyncmame .61 beta 2. thanks.
Ummon
  • Trade Count: (+13)
Re: vsyncmame .61
« Reply #3 on: June 04, 2008, 12:36:25 am »
What's your reason for using this build?
Yo. Chocolate.
Stephen Hawking
tikbalang
Re: vsyncmame .61
« Reply #4 on: June 05, 2008, 08:21:06 am »
i'm collecting dos emulators.
