Author Topic: AM-0316 schimatic  (Read 1655 times)
Arm123
  • Last login:March 03, 2025, 11:26:20 am
AM-0316 schimatic
« on: May 30, 2008, 02:07:15 am »
I have this chassis sitting here, with a burnt R91 and cant make out the color code.
here is a pic of the chassis, its the same...
http://arcadecontrols.com/BBBB/am.html
Anyone know what the value of R91 is ?
Ken Layton
  • Guru
  • Technician
Re: AM-0316 schimatic
« Reply #1 on: June 03, 2008, 06:05:10 pm »
Might be a 2.2 ohm 2 watt flameproof. Generally if this resistor burns it's because the vertical output IC is shorted. So replace the vertical output IC and the resistor both.
Arm123
« Reply #2 on: June 03, 2008, 11:44:40 pm »
Thanks alot Ken.
Inititally i 'tried' to read the burnt colors off the resistor.  I got ether 1.3 / 1.3k and I decided to try the 1.3.
The CRT sounded like it powered up, but i saw no neck glow.  I left it on for a bit and then heard sounds like it was struggling to sync.  Still no picture.
Unplugged and checked la7831, GND (pin 3) was shorted to Vertical out (pin 4). Another $7 gone ;-P
Also checked the diode that was between the burnt resistor and the Vcc terminal pin 6 of LA7831 and its shot as well.
Ill have to get a 2.2 ohm 2 watt flameproof and new diode.  I hope this does the trick.
