Author Topic: Monitor "Squiggle"  (Read 2542 times)
davido
  • Last login:June 23, 2008, 10:12:32 pm
Monitor "Squiggle"
« on: May 29, 2008, 09:31:35 pm »
First time on site, not sure if this is how to post a question. Sorry. I have a "std." arcade monitor. I have noticed a small (1" or so) section along the top and bottom of the monitor that have an s-shaped squiggle. The rest of the screen is ok. I've checked the voltage at the power supply, which was 5.3 V and -4.9 V. I've switched the motherboard with other jamma ready games and no change. Would this be a monitor chassis issue? Thanks, David
SirPeale
  • Green Mountain Man
Re: Monitor "Squiggle"
« Reply #1 on: May 30, 2008, 12:02:29 am »
Sounds like a small sync issue.  Might want to try adjusting your horizontal or vertical hold, see if that helps.
You should also post the monitor make and model.  Did you see the post that is in all caps?
davido
« Reply #2 on: June 23, 2008, 09:57:18 pm »
Ok, thanks a lot. I'll try that. David
Ninja-chicken
  • Last login:September 27, 2009, 05:06:08 pm
« Reply #3 on: June 27, 2008, 10:15:07 am »
I have a "std."
You should see your doctor about this :)
</lamejoke>
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« Reply #4 on: June 27, 2008, 11:49:38 am »
"gono-syphi-herpales" ???
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
castlesteve
  • Last login:September 12, 2014, 09:10:32 am
  • uh, yea
« Reply #5 on: June 27, 2008, 06:42:50 pm »
ground the monitor chassis and make sure your power supply is properly grounded.  Then try a cap kit
