Author Topic: Help with painting issues  (Read 1957 times)
str1der
  • Last login:March 04, 2021, 04:35:31 pm
  • Live it!
« on: June 02, 2003, 12:15:51 am »
I've been working on my cabinet made with 3/4" MDF and I'm using Rustoleum Hammer finish paint on it. I've been using a 6 " sponge roller. I've put three coats on the sides but I can't get rid of roller marks. Is there any tricks or words of wisdom to get rid of them?
Hoagie_one
  • Um....whats a cabinet
Re:Help with painting issues
« Reply #1 on: June 02, 2003, 12:33:39 am »
two ideas.
1)  make sure you give it a light sanding between coats.  Each time with a finer grit.
2) dont roll in straight lines.  Go across, then down then side, then across then get the spots you missed.  Hard to explain but i saw it on trading spaces, lol
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: June 02, 2003, 01:41:13 am »
You also need a high quality roller.  Not sure if your sponge roller is "high enough" quality.  I can't tell the difference between medium and high quality; I ask the hardware clerk to show me the which ones are the best.  *shrug*  Maybe someone here can me (us) on this?
Robin
Knowledge is Power
str1der
  • Live it!
« Reply #3 on: June 02, 2003, 02:15:18 am »
I used what they said were high quality rollers. Am I using to much pressure when painting possibly?
Sprucemoose
  • Last login:March 23, 2009, 03:56:10 pm
  • You Spent How Much?!
« Reply #4 on: June 02, 2003, 10:40:53 am »
Its possible.  A little paint goes a long way.  After you are done with a side look at the glare and see if you see any roller marks, if roll them out like Hoagie suggested.
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #5 on: June 02, 2003, 10:54:38 am »
After the first coat of paint, I used a lot of very light coats, loading the roller maybe only twice per big side.  Sometimes just barely touching the roller to the wood - I'd go over the edge of the last stroke until it dissapeared, and when it dried it blended much better.
str1der
  • Live it!
« Reply #6 on: June 02, 2003, 11:02:09 am »
Frost, I assume you were using a sponge roller.
Frostillicus
  • Arcade Artist
« Reply #7 on: June 02, 2003, 08:52:39 pm »
I guess - they are made by Shur-Line.  It says foam roller, which is sponge I assume.   This gave a smoother texture than the 'fine' fabric roller I used on my last cab.
