Author Topic: Started building a cabinet.....  (Read 2945 times)
y2kgtp
  • Last login:June 09, 2008, 02:02:40 pm
« on: May 27, 2008, 11:37:28 pm »
I was bored, so got some 1/2 Ply and went to work.  This was based loosely off a "William's Defender Stargate 2&1 cabinet"  as I liked the look of it, but downsized a bit to fit a 20" TV I had laying around and also make the most of a 4x8 sheet.  It is 5'5" tall, and will be slightly higher when I get some casters under it.  I actually got almost all the wood off of a 4x8 sheet, as each side was cut to be 2' deep.  I added 4" of the front bump out with some spare wood off the board.
I was going to put a couple Jaccs games I bought used off of eBay in it (pacman, galaga, pole position, etc), with a A/B box to switch between the 2, but still undecided.  I have Happs controls sitting in a box already as well.......
Still undecided if I am going to cover it, or just paint it black, or whatever.....just a work in progress.....my wife still thinks I'm nuts...
Thanks to Craig C who replied to my emails a few weeks back and suggested 1/2 ply.....it's really easy to work with.
y2kgtp
Re: Started building a cabinet.....
« Reply #1 on: May 27, 2008, 11:50:25 pm »
I don't have anything for a back yet....was not sure if I was going to use 1/2 ply, or get some of that pegboard stuff?
Plan on doing some t-moulding as well.....but I got time for that.....
spystyle
« Reply #2 on: May 28, 2008, 07:05:51 am »
Sweet, a mini Defender is born!
y2kgtp
« Reply #3 on: May 29, 2008, 11:03:21 pm »
Got controls wired to the 1st Namco unit, all works! I am going to wire in a 2nd Namco 5 in 1 to the same controls, and switch between the 2 with a power A/B type toggle.
Controls will get moved around, as I don't like the layout, and I still need to find a wheel for the pole position game.....(shaft is in the center of the panel board.)
« Last Edit: May 29, 2008, 11:04:56 pm by y2kgtp »
vertygo
  • Last login:September 20, 2015, 03:19:59 pm
« Reply #4 on: May 30, 2008, 02:16:25 pm »
Looking good.. I really like the shape. Can't wait to see some paint on it.
