Author Topic: When good resistors go bad ;-)  (Read 1578 times)
Arm123
  • Last login:March 03, 2025, 11:26:20 am
« on: May 26, 2008, 12:26:30 pm »
I have a quick question for those with more experience.
I had a monitor lose vertical deflection and give me a hrz line across the screen.  I looked around and discovered a FR, off the flyback, to a diode + la7831 had gone open.  The diode was fine.
I thought i should at least 'try' to just replace the resistor and try it.  It did actually work !
My question is...   There has to be a reason for it right ? Can a resistor just go open like that for no good reason ?
Just trying to learn something from this, so I’m 'open' to speculation.   :P
Ken Layton
  • Guru
  • Technician
Re: When good resistors go bad ;-)
« Reply #1 on: May 26, 2008, 12:59:25 pm »
Yes, sometimes a resistor can just go open. If it goes bad again, replace the IC.
Arm123
« Reply #2 on: May 26, 2008, 01:14:22 pm »
Thanks Ken,  Ill wait and see how long she lasts.
