Author Topic: Mame / MameWah / Coindoor issue  (Read 1283 times)
Retro_SA
  • Last login:July 12, 2010, 08:38:17 am
« on: May 26, 2008, 04:25:30 am »
I have a problem with certain games not registering the coins from my coin door.  I can't figure out where the problem is.  For example:
Super Bubble Bobble always registers the coin inserts.
Rygar registers like every 10th coin.
The coins still goes through, its not getting rejected, but it just doesn't register in Mame / MameWah.
If it's working perfectly for certain games, then surely it can't be the coin door?  I'm using the mini-pac.
Ginsu Victim
  • Last login:June 28, 2025, 10:45:55 pm
  • Comanche, OK -- USA
Re: Mame / MameWah / Coindoor issue
« Reply #1 on: May 26, 2008, 10:17:18 am »
Mamewah wouldn't have anything to do with it.
Rygar never gives me problems. What version of MAME are you using?
Retro_SA
« Reply #2 on: May 26, 2008, 01:02:55 pm »
I'm using Mame 0125b.  Is that the correct one to use?  I'm also getting some other weird problems.  Like with Snow Bros when I insert a coin, it shows "coin error".
ideft
  • Last login:February 11, 2012, 04:06:09 pm
  • "Mister, I suspect you to be a dope fiend"
« Reply #3 on: May 26, 2008, 06:54:35 pm »
Remap the coin insert to a button or a shifted button in the games you are having trouble with to narrow down where the problem is coming from.
