Author Topic: cutting the CPO  (Read 2666 times)
clickhea
  • Last login:August 09, 2019, 07:33:40 am
cutting the CPO
« on: May 20, 2008, 01:09:24 pm »
when you guys cut your cpo button holes did you actually cut a circle out or can u just slice an X and place the buttons in like that?
also how do you cut perfectly around the trackball without screwing it up :|
Ginsu Victim
  • Comanche, OK -- USA
Re: cutting the CPO
« Reply #1 on: May 20, 2008, 02:55:22 pm »
I simply cut an X and pushed my buttons in, however I'm just using a poster, not a real CPO.
AcidArmitage
  • Last login:February 21, 2015, 02:19:05 am
  • keeeyaaaii
Re: cutting the CPO
« Reply #2 on: May 20, 2008, 04:32:35 pm »
i cut a double X... or an X and a + sign if you wanna be a bastard about it   >:D
clickhea
Re: cutting the CPO
« Reply #3 on: May 20, 2008, 05:28:20 pm »
same thing for the trackball?
Ginsu Victim
Re: cutting the CPO
« Reply #4 on: May 20, 2008, 05:32:12 pm »
For the trackball, just take an exacto knife and start in the center. Cut from the center until you hit an edge, then work slowly around the hole staying against the edge.
fjl
  • Pixels Rule!
Re: cutting the CPO
« Reply #5 on: May 20, 2008, 05:45:20 pm »
The more slices you add the better it will look.
fatfingers
  • Got UltraStiks?™
Re: cutting the CPO
« Reply #6 on: May 20, 2008, 05:56:18 pm »
I used X-acto knife for all holes -- worked really well.  I didn't use the X method.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: cutting the CPO
« Reply #7 on: May 20, 2008, 07:45:25 pm »
x-slicing and folding can be good if done right, but make sure to make many slices. As the edges fold into the hole, there is less chance of shrinkage exposing the edges around the hole over time and it will also prevent minor rubbing from catching those trimmed edges and potentially tearing the overlay.
DaveMMR
Re: cutting the CPO
« Reply #8 on: May 20, 2008, 10:41:31 pm »
I actually cut out the full circles for the buttons but only because, with the button bezels, there's a bit of room for error (it hides it).  Slicing will work too (at least four slices I'd guess) if you'd like, but you're not saving a heck of a lot of time if you're using a semi-decent Exacto.
The trackball is where you really have to take your time.  I used the mounting place hole as a guide.   Also add the "joystick hole" to the "careful list" if you're hiding your washers.
clickhea
Re: cutting the CPO
« Reply #9 on: June 04, 2008, 07:25:14 pm »
any tips on cutting out the trackball iam really nervous
DaveMMR
Re: cutting the CPO
« Reply #10 on: June 04, 2008, 07:27:03 pm »
Read about 3 inches up from your last post. ;-)
clickhea
Re: cutting the CPO
« Reply #11 on: June 04, 2008, 07:54:16 pm »
oops totatly missed that somehow
miles2912
Re: cutting the CPO
« Reply #12 on: June 04, 2008, 08:05:20 pm »
I believe with i just free handed it with a brand new sharp blade.  Your tb overlay should be mounted already and you can feel where the circle should be.  Might be easier to flip the entire cp over.  I remember sweating over the tb hole too.
As far as the buttons are concerned, i cut out a hole pretty close to the edge and just pushed the buttons the rest of the way.
